查看: 2136|回復: 1
AmiBroker 5.81.0 BETA released
發表於 14-8-22 07:00 | 顯示全部樓層 |閱讀模式
AmiBroker 5.81.0 BETA releasedStability: – Regular BETA, pretty stable, should work fine in most environments
A new beta version (5.81.0) of AmiBroker has just been released.
32-bit version:
http://www.amibroker.com/members/bin/ab5810beta.exe
(2 305 496 bytes)
64-bit version:
http://www.amibroker.com/members/bin/AmiBroker5810x64.exe
(9 722 200 bytes)
CHANGES FOR VERSION 5.81.0 (as compared to 5.80.3)
  • AFL Engine: custom memory allocator does not use Microsoft runtime lib for reference tracking anymore. Result – complex formulas with lots of loops and OLE (especially low-level custom backtests) run upto 3 times faster in 32 bit and 4 times faster in 64-bit
  • AFL Editor: Parameter info tip significantly enhanced – now it re-opens on typing each , (comma) and highlights current parameter to be entered.
  • UI: Column setup dialog: added Mark All / Toggle All buttons
  • AFL: GetFormulaPath() function added – returns full formula file path
  • AFL Editor: Smart reference highlighting implemented (usage: mark a word and all references become highlighted).
  • AFL Editor: Find/Replace shows a message box when reached the end of the file and offers restarting from the beginning if new “Wrap around” option is turned on.
  • AFL Engine: code refactoring for reduced size and improved speed
  • AFL Engine: when value of unsupported type was appended to string a crash could occur. Fixed.
  • AFL Engine: when IIf was called the memory upsized from scalar to array could get freed twice (wrong). Fixed
  • AFL: MACD() and Signal() functions made faster (approx 1.5-2x times)
  • Analysis: Interest is added at the beginning of next bar (instead of end of current bar), to account for overnight rate. This also fixes the problem of ignoring interest in v.> 5.69
  • UI: fixed yet another place where entering customization changed working dir
KNOWN ISSUES:
  • No known.
For more details, instructions and examples how to use new features see the 5.81.0 BETA READ ME
參與人數 1金錢 +5 收起 理由
kilroy + 5 感謝分享
發表於 14-8-22 14:27 | 顯示全部樓層
感謝提供資訊~~~
下載來試用~~
GMT+8, 26-11-5 06:07
