2014-12-31 今年最後一天
 火... [複製鏈接]
發表於 14-12-31 12:31 | 顯示全部樓層
今年最後一天啦!!!
發表於 14-12-31 12:32 | 顯示全部樓層
真的是最後一天了
afang0981 + 2 新年快樂
發表於 14-12-31 12:37 | 顯示全部樓層
.........新年快樂!!
http://youtu.be/bgVecrWY3w8
小胖懷疑影片裡面的 全部都是機器人.......
參與人數 1金錢 +3 收起 理由
manhavecoco + 3 感謝分享
發表於 14-12-31 12:38 來自手機 | 顯示全部樓層
taitanwu 發表於 14-12-31 12:18
還是不願意上去,放棄,來去接小朋友下課~~
肯上去了嗎????
manhavecoco + 1 您不適去接小孩
發表於 14-12-31 12:44 | 顯示全部樓層
加油啊 就差這麼一點點 上去吧
glaxo + 2 太強了
mewmi + 1 按一個讚
發表於 14-12-31 12:46 | 顯示全部樓層
harvey 發表於 14-12-31 12:37
.........新年快樂!!
這是什麼東東呀.... 完全看沒有XD ...............
發表於 14-12-31 12:55 | 顯示全部樓層
mewmi 發表於 14-12-31 12:46
M大.........請問一下 MC語法.....感恩感恩就是阿.........在K線圖上面 經過邏輯判斷後 想要移除已經標示在左方K線上面的 線 或 文字
這 要用那個指令阿.......
發表於 14-12-31 12:59 | 顯示全部樓層
本帖最後由 mewmi 於 14-12-31 13:01 編輯
harvey 發表於 14-12-31 12:55
M大.........請問一下 MC語法.....感恩感恩就是阿.........在K線圖上面 經過邏輯判斷後 想要移除已經標示 ...
好吧.. 反正方向對了... 就剪貼一下吧....
Text_Delete
Removes a text object with the specified ID number from a chart; returns a value of 0 if the object was successfully removed, and a value of -2 if the specified object ID number is invalid.
UsageText_Delete(ObjectID)
Where: ObjectID - a numerical expression specifying the object ID number
Notes An object-specific ID number is returned by Text_New when the text object is created.
ExampleRemove the text object with an ID number of 3:
Value1=Text_Delete(3);
要放假了... 來找偶呀........
差點漏了這個... 又是線又是文字的XD ............
NoPlot
Removes a specified plot from the current bar. A conditional plot that is already drawn will remain even if the conditions become no longer true before the bar is closed. NoPlot can be used to remove the conditional plot from the current bar if the conditions are no longer true.
UsageNoPlot(PlotNumber)
Where: PlotNumber - a numerical expression specifying the plot number; plot numbers range from 1 to 999
ExampleThe example below uses NoPlot remove the PlotPaintBar plot "painted" over the chart bars for which the High price is no longer less then the High price of the previous bar:
If High<High[1] Then Begin
PlotPaintBar(High,Low,"",Red);
End
Else Begin
NoPlot(1);
NoPlot(2);
End;
Without NoPlot, chart bars for which a High price was initially less then the High price of the previous bar would remain partially ainted� even if a High price equal to or greater then the High price of the previous bar was reached before the bar was closed.
harvey + 2 感謝分享
發表於 14-12-31 13:05 | 顯示全部樓層
mewmi 發表於 14-12-31 12:59
Text_Delete
哎呀.........小胖笨了 .........都在這裡....
http://www.multicharts.com/trading-software/index.php/Category:Text_Drawing
發表於 14-12-31 13:12 | 顯示全部樓層
taitanwu 發表於 14-12-31 12:38
肯上去了嗎????
5分鐘就到了阿~~
沒盯著看就跑上去了..
難玩~
現在到家了~
發表於 14-12-31 13:15 | 顯示全部樓層
9290 掛價空,All in
參與人數 1金錢 +5 收起 理由
manhavecoco + 5 新年快樂 ^^
給參加週結算的COCO戰友們加油
13:00~13:15 加權指數算數平均值 = 9276
參考一下
參與人數 1金錢 +5 收起 理由
manhavecoco + 5 新年快樂^^
發表於 14-12-31 13:19 | 顯示全部樓層
超級美少女 發表於 14-12-31 13:15
9290 掛價空,All in
今年要收攤了 才開燈  市要開跨年喔?
發表於 14-12-31 13:21 | 顯示全部樓層
9290 掛價空,All in
ALL IN指令出現了
我已經沒有coco可以馬丁了
發表於 14-12-31 13:22 | 顯示全部樓層
selene 發表於 14-12-31 13:19
今年要收攤了 才開燈  市要開跨年喔?
空單留倉好過年..........
GMT+8, 26-11-24 13:54
