樓主: 小娃
AmiBroker購買或試用
發表於 10-10-6 23:56 | 顯示全部樓層
回復 31# good88
   我是指購買正版以後 可以下載一個註冊的檔案我想問的是那個註冊的檔案可以用來註冊兩台不同電腦的AMIBROKER嗎?
發表於 10-10-8 19:15 | 顯示全部樓層
前幾天也買了一套來玩玩...
不知是否可以二台同時上網更新資料?
若不能二台用...以後有新測試版時要如何?
發表於 10-10-8 19:34 | 顯示全部樓層
回復 33# lutin111
   我測試過了 可以同時註冊兩台電腦
發表於 10-10-8 19:44 | 顯示全部樓層
Single license use on multiple computers?
That is the common question we receive through support channel, so even though it is explained in the LICENSE.TXT file that you have in your AmiBroker folder, let us make some facts straight.
First take a look what the license says:
        “REGISTERED VERSION:
        One registered copy of the program may either be used by a single person who uses the software personally on one or more computers, or installed on a single workstation used non-simultaneously by multiple people, but not both.
        You may not disclose registration key(s) to non-registered users.
        Storage/Network Use. You may also store or install a copy of the Software on a storage device, such as a network server, used only to install or run the Software on your other computers over an internal network; however, you must acquire and dedicate a license for each separate computer on which the Software is run from the storage device. A license for the Software may not be shared or used concurrently on different computers.”
So the answer to most common question: “Can I install and use it on both desktop and laptop?” is YES, you can.
It is however NOT allowed to use single license to RUN SIMULTANEOUSLY on MULTIPLE machines connected via network, like for example running optimization on many machines in parallel. For that you must purchase license for every machine you are using simultaneously.
發表於 10-10-8 19:45 | 顯示全部樓層
本帖最後由 lutin111 於 10-10-8 07:47 PM 編輯
看這文好像不能二台同時上網吧
就怕上多次後給它封了...
發表於 10-10-13 19:33 | 顯示全部樓層
請問:
Amibroker "標準版standard"可以自設指標嗎? 適用奇狐公式語法嗎?
可看台指期即時1分K嗎?
可看即時的國際股匯市1分K嗎?
使用奇狐很多年了, 是很好用, 可是太貴了, 因我只看台指期即時1分K,只看自設的3個指標,
聽各位大大介紹AB,真的便宜太多了, 還請諸位大大解惑.....
感恩........
發表於 11-3-25 12:41 | 顯示全部樓層
太棒的分享了~~~太棒的分享
發表於 11-4-27 21:55 | 顯示全部樓層
http://www.amibroker.com/guide/
AmiBroker 5.40 User's Guide 四月廿六已出場(Google 裏無意中看到的).
發表於 11-5-20 13:27 | 顯示全部樓層
AmiBroker是一套很棒的軟體。
官網
他們很貼心的提供試用,
試用和正式版一樣。
試用好像是30天,忘了。
小娃 發表於 09-9-21 01:13 PM
    請問大大,費用是多少?
發表於 12-1-11 21:28 | 顯示全部樓層
發表於 12-4-20 12:28 | 顯示全部樓層
AmiBroker 的語法跟function 說明
台灣有出書嗎
去那找說明ㄚ~
謝謝~~
發表於 12-4-20 12:33 | 顯示全部樓層
很想買一套來用
可惜目前都找不到
如何才能全自動下單的作法
發表於 12-5-22 23:03 | 顯示全部樓層
j202036 發表於 12-4-20 12:33
很想買一套來用
可惜目前都找不到
如何才能全自動下單的作法
全自動下單有別的blog寫得很詳細
AB+ABTW+下單大師
非常的詳細
我權限不夠,無法貼url
發表於 12-7-7 17:57 | 顯示全部樓層
感謝分享~~~~~~~~
發表於 12-9-8 17:16 | 顯示全部樓層
AmiBroker 5.50 User's Guide
已經到5.5版了...
GMT+8, 26-11-4 22:24
