查看: 3679|回復: 1
AmiBroker 6.12.0 BETA released
發表於 16-4-2 10:44 | 顯示全部樓層 |閱讀模式
April 1, 2016
A new beta version (6.12.0) of AmiBroker has just been released.
32-bit version:
http://www.amibroker.com/members/bin/ab6120beta.exe
(2 215 720 bytes)
64-bit version:
http://www.amibroker.com/members/bin/AmiBroker6120x64.exe
(10 431 400 bytes)
Note that this version can only be installed onto previous full installation of version 6.10 or higher from
http://www.amibroker.com/download.html
CHANGES FOR VERSION 6.12.0 (as compared to 6.11.0)
  • AFL: new function GfxDrawImage( “filename”, x, y )
  • AFL: new function CumProd( factor ) – cumulative product of array elements
  • AFL: new function Prod( array, range ) – cumulative product of array elements over specified number of bars (range)
  • AFL: new function ProdSince( condition, array ) – cumulative product of array elements since condition is met
  • AFL: new function VoiceSelect( num ) – select SAPI (Speech API) voice to be used with Say() function, num is a numerical index of installed voices. By default Windows comes with just one voice, but one can add countless 3rd party voices
  • AFL: new function VoiceCount( ) – returns number of available SAPI (Speech API) voices – to be used with Say() command
  • AFL: StaticVarAdd with non-array input produced incorrect results. Fixed.
  • UI: New Analysis: Alt+Enter shortcut added to bring up settings window
  • UI: Quote Editor allows now immediate search for matching date – just type digits in format YYYYMMDD and list will automatically scroll and mark to quote that most closely matches entered date
  • UI: Realtime quote window: a RMB context menu items are grayed when local data is used and an empty message is set to inform the user that he/she needs realtime data source to use this window
  • UI: Symbol Information – date fields (like last split date, div date or delisting date) can now be cleared (select all and press DELETE) to set Empty/Null date
  • UI: Symbols with COMMA (,) caused problems with multiple-selection operations. Now it is handled properly.
lwhuang + 2 感謝分享
發表於 16-4-3 10:39 | 顯示全部樓層
看來可以叫他說話了,Text to speech
GMT+8, 26-11-5 05:10
