查看: 5277|回復: 0
AmiQuote 3.15 released
發表於 17-6-2 09:20 | 顯示全部樓層 |閱讀模式
June 1, 2017AmiQuote 3.15 releasedA new public version of AmiQuote 3.15 is available for download from
http://www.amibroker.com/bin/aq3150.exe  (113KB) – 32 bit version
http://www.amibroker.com/bin/aq3150x64.exe  (135KB) – 64 bit version
IMPORTANT! Yahoo Historical download now REQUIRES Windows 7 or higher. On Windows 7 it requires Internet Explorer to be installed in the OS. It also REQUIRES AmiQuote License.
This version fixes problem with Yahoo Historical and Yahoo Fundamental Extra sources that stopped working after changes on Yahoo site.
The upgrade is free for all previously registered AmiQuote users.
Since some people complain that the functionality is no longer free – if you do not want to pay a penny for the program that saves hours of your time – please download your data manually by clicking on Yahoo pages using browser of your choice. It is up to you. Developer time does not cost zero and we do not sell advertisements, so we expect to get paid as you do in ‘normal’ life.
INSTALLATION INSTRUCTIONS:
Precise instructions are here: http://www.amibroker.com/kb/2017/05/18/how-to-install-amiquote-3-14-correctly/
TROUBLESHOOTING:
  • The download is not adjusted for DIVIDENDS. It is adjusted for SPLITS only. That is how Yahoo delivers the data now and you can’t do anything about that
  • If you are getting “Failed to update registry, use REGEDIT” message, then you need to run AmiQuote at least once with administrator rights – to do so click on AmiQuote icon with right mouse button and select “Run As Administrator”
  • If you are getting close and volume data exchanged then it means you did not install properly the program and updated aqh.format file is missing. You must make sure that aqh.format file inside Formats directory is NEW (from May 17, 2017). It is included in the setup program so just follow instructions above.
  • If you are not able to download more than 2 years worth of data it means you entered too early “From” date. For example if you enter 1900 as “from” date you won’t get more than recent 2 years. But if you enter more resonable starting date such as year 2000, then you will be able to download 17 years worth of data
  • The download hangs on Windows XP and Vista – new Yahoo Finance pages are incompatible with Windows XP/Vista, and specifically with Internet Explorer 9 or lower that Windows XP/Vista shipped with. Windows XP and Vista are obsolete and not supported anymore by Yahoo. You need at least Internet Explorer 10 to be installed (Windows 7)
  • If it still does not work – you did something wrong. The program works fine, as long above steps are PRECISELY done. Rinse and repeat until it clicks.
CHANGES FOR VERSION 3.15 (as compared to version 3.14)
  • Added checks for Internet Explorer 10 or higher installation (required by Yahoo Historical downloads)
  • Added checks for “From” date earlier than 1970 (Yahoo historical does not support earlier dates now)
  • Updated Quandl downloader to use EOD source for US stocks (instead of old “WIKI”)
  • Quandl downloader now supports use of other sources than EOD. You can use symbols with slash that refer to other Quandl databases (like SCF/SHFE_ZN2_OR) but keep in mind that other sources than EOD usually have different layout of downloaded data and you would need to import those data manually (at least until some universal method is found)
  • Other minor changes/fixes
GMT+8, 26-11-5 02:12
