查看: 54209|回復: 0
AmiBroker 6.31.0 BETA released
發表於 19-8-5 09:28 | 顯示全部樓層 |閱讀模式
August 2, 2019AmiBroker 6.31.0 BETA releasedStability: – regular BETA should work fine in most environments
A new beta version (6.31.0) of AmiBroker, with new functionality in Batch controller has been released.
32-bit version:
http://www.amibroker.com/members/bin/ab6310beta.exe
(2 422 504 bytes)
64-bit version:
http://www.amibroker.com/members/bin/AmiBroker6310x64.exe
(11 000 224 bytes)
UPGRADE POLICY
This version is a free upgrade only for users who registered AmiBroker after August 1, 2017. Users who registered earlier, would need to purchase license upgrade. To find out the version you currently have use Account Information page at http://www.amibroker.com/members/info.php
Note that this version can only be installed onto previous full installation of version 6.30 or higher from http://www.amibroker.com/download.html
FEATURE HIGHLIGHT 6.31
6.31 is focused on Batch window improvements and general fixes. See CHANGE LOG for details.
CHANGES FOR VERSION 6.31.0 (as compared to 6.30.0)
  • AFL: Access violation in PercentRank when period is wrong. Now error 52 is displayed instead.
  • AFL: InternetPostRequest now silently (or with warning 507 under debugger) returns NULL handle instead of error when remote server responds with HTTP Status 50x
  • Analysis: manual column re-sorting could be bit off if scientific output format (xxxEyyy) was used with different exponents. Fixed.
  • ASCII importer now handles LastSplitRatio of X:Y where X and Y are 1…32767 (previously only 1..127)
  • Batch: add “add results to watchlist” action / WatchlistAddResults
  • Batch: add “clear watchlist” action / WatchlistClear
  • Batch: add “comment” action
  • Core/DB: fixed access violation when all data were removed while QuickData was turned on
  • DebugView: eliminated some internal messages from DebugView output (from release version)
  • InternetPostRequest – even if URL started with https, previous version wanted to connect to port 80, instead of 443. Fixed.
  • UI/Listview: since 6.28 exception could occur if single cell text length exceeded 1024 characters. Fixed.
  • When database is empty, ticker box displays  grayed text instead of blank or reminiscent of previous database symbol
KNOWN ISSUES:
  • None
For more details, instructions and examples how to use new features see the 6.31.0 BETA READ ME
Filed by Tomasz Janeczko at 8:27 am under Beta,Releases
Comments Off on AmiBroker 6.31.0 BETA released
GMT+8, 26-11-5 02:11
