查看: 8366|回復: 33
甚麼地方最容易形成當日最高點或最低點?
發表於 12-6-6 11:36 | 顯示全部樓層 |閱讀模式
我曾經統計大約一個月左右的時間,
甚麼地方最容易形成最高點或最低點?
答案如附圖.
符合股票箱作者的論述.
前日的高低點及收盤點位,密集成交區,千百點位置,均線位置,波段高低點.
出現次數如附圖.
像今日到目前為止最低點在6960附近.
是昨日收盤前一刻交易最密集的位置.
附圖也可見到收盤水位6970有主力留倉.
發表於 12-6-6 11:38 | 顯示全部樓層
版大 午安
 樓主| 發表於 12-6-6 11:41 | 顯示全部樓層
減少交易才是當沖生存之道,
忘了這篇文章的出處,對作者很抱歉,善心人士幫忙翻譯,謝謝[我是菜英文一族]
Most people looking to make money in the markets believe that the answer lies in finding some simple technical analysis strategies that will catapult them to profitability.
The truth is that trading is not as simple as beginners believe. It is a profession, and like any profession it requires a learning curve. Reading a book or getting a few simple "tips" is not going to turn you into a professional trader.
After studying for a length of time, it's not uncommon for students to begin their search for the "holy grail."
They search for more indicators, chart patterns, gurus, alert services or the latest secret day trading strategies and other things that will provide their answer to becoming successful.
But here's the fact. Success lies within you .. and it won't come easy.
In fact, one of my favorite success principles is this:
"Successful people do what unsuccessful people are unwilling to do."
Let's apply this to trading in the form of my list of "Day Trading Rules to Live By" ... all of which have to do more with you than with the market.
1.        The consistency you need is in your mind, not in the market. Many in the market get frustrated because the market often behaves differently than they expect. You can't rely on the market to be consistent. It is largely a random walk. But there are times when the market does setup with a probability scenario that gives you an edge. Your job is be consistent in trading those probability setups and trade them every time they occur.
2.        Trade like a cat. Most beginners over trade. It's one of the most common trading sins. Your job is to be better than other day traders in having the discipline to wait like a cat in the brush until just the right moment (your high probability setup) and then jump on the trade without hesitation……….
3.        Successful trading is simply a game of not making mistakes. Keep a list of your day trading rules posted on the wall or on your monitor and then follow those rules perfectly. You must be more disciplined than the average trader. Never depart from your rules no matter how good a trade "looks" or "feels" to you if it violates your objective and back-tested rules.
4.        Only trade when you are in an optimal emotional state. Never trade when you are tired or are in an emotionally unstable situation (after a fight with a spouse or friend for example). Day trading is more like athletics than academics. Trading on such a short time frame requires you to be able to make split second decisions, and you're risking a lot of money when you do. Make sure your mind is sharp and your emotions are centered.
5.        Keep a detailed trading log. Every day trading course I've seen has a trading log. Yet my experience in dealing with trading students demonstrates that less than 10% of them actually use it. This is a huge mistake. Not only should you log every trade, but you should also record how you felt and what you were thinking as you took the trade. In this way your logs will become a type of "biofeedback" mechanism for you. Personally, this was the difference that made all the difference for me.
These 5 day trading rules are not the type of rules that you were probably looking for. The masses want rules about indicators, price bars, where you get in and where you get out.
Granted, you definitely need clear objective rules about those things as well. Yet thousands of traders have those types of rules, and yet continue to fail because those rules are about market action.
They fail because they don't have, or don't follow, the more important rules the rules about their own action.
winforjs + 1
 樓主| 發表於 12-6-6 11:46 | 顯示全部樓層
忘了註明附圖是2012/6/5 的五分K線圖.
發表於 12-6-6 11:48 | 顯示全部樓層
請問大大的密集成交區是往前推幾天的累積成交量
均線的話,大大怎麼做統計
謝謝大大分享
 樓主| 發表於 12-6-6 11:59 | 顯示全部樓層
附圖洋紅色是當日的成交量,左下角橙色是前日[6/4]一日的點位交易量.
我記錄的有
一日[隔日沖]
五日[周沖]
十日[半月沖]
均線記錄5日,10日,20日
就是周,半月,月.
發表於 12-6-6 12:31 | 顯示全部樓層
5分k的最大量 容易有高低點
發表於 12-6-6 13:04 | 顯示全部樓層
還是跟著盤走
只有大概 相對
沒有 絕對
發表於 12-6-6 14:07 | 顯示全部樓層
TN543 發表於 12-6-6 11:41
減少交易才是當沖生存之道,
忘了這篇文章的出處,對作者很抱歉,善心人士幫忙翻譯,謝謝[我是菜英文一族 ...
文章應是引自"Day Trading Rules to Live",作者是 Dr. Barry Burns。
winforjs + 1
 樓主| 發表於 12-6-6 16:18 | 顯示全部樓層
lucas 發表於 12-6-6 12:31
5分k的最大量 容易有高低點
有人說過只靠著成交量的一根主桅竿[特別突出的成交量],搭配特長的上下影線出現時進場,
一年只交易60天就累積了大筆財富,這大概是另類的王醫師吧.
像上面那篇英文裡面所提到的貓一樣,耐心等候,瞬間出手.
而一般散戶,也就是同文所提到的輸家,總是過度交易.
想要靠期貨來養活自己,結果反而是自己在養期貨公司.
發表於 12-6-6 18:26 | 顯示全部樓層
TN543 發表於 12-6-6 16:18
一年只交易6 ...
說的太好心有戚戚, 當日沖銷的本意指的是不留倉,不是整日衝(沖)來衝(沖)去....
發表於 12-6-6 18:32 | 顯示全部樓層
減少交易才是當沖生存之道,
英文很差,只能用google翻譯來看
不過,國外的著作水準真的較高
發表於 12-6-6 18:35 | 顯示全部樓層
謝謝分享,不錯的統計分析 ~
發表於 12-6-7 08:11 | 顯示全部樓層
一年只交易6 ...
"而一般散戶,也就是同文所提到的輸家,總是過度交易.
想要靠期貨來養活自己,結果反而是自己在養期貨公司."
大大說到小弟的心坎裡了......
winforjs + 1
發表於 12-6-7 10:40 | 顯示全部樓層
GMT+8, 26-11-15 00:45
