查看: 2872|回復: 1
Unbattle, you did not import correctly
發表於 12-8-4 21:53 | 顯示全部樓層 |閱讀模式
Hello,
I don't speak your language at all. Sorry! So I have to use an universal language like English instead
Regarding post #6
You did not correctly import the tick data to Amibroker!
You must use $TICKMODE 1 to import all tick quotes!
Read the Amibroker manual. The following is an extract from the manual
Command $TICKMODESwitches on/off tick mode
      $TICKMODE is a special mode of importer that allows to import quotes that      have duplicate time stamps.
If you use $TICKMODE 1 (1 means TRUE) as addional import command then your Amibroker chart will look like picture showing the Multicharts chart
So no bye bye but hello hello because you have not used it corrctly according to your needs. Amibroker can do everything.
I'm not from Amibroker but just another user coming to this link via Google search
Can anybody tell me how to upload picture. What button do I need to click?
 樓主| 發表於 12-8-4 21:57 | 顯示全部樓層
Sorry I pressed the wrong button. The Post should belong to here http://coco-in.net/thread-15071-1-1.html
GMT+8, 26-11-5 05:59
