查看: 2509|回復: 4
請問如何儲存optimize結果
發表於 12-11-16 01:48 | 顯示全部樓層 |閱讀模式
optimize run玩之後 會有結果
關閉AB後 我希望下次還能夠 看到這個結果
不過按了 Save as 之後 再打開來...結果都不見了
請問 要怎麼儲存 optimize的結果呢?  (除了excel 因為他只能儲存100萬row)
謝謝^^
發表於 12-11-16 04:25 | 顯示全部樓層
If using Amibroker 5.5 or 5.6:
Go to File -> Export HTML/CSV and save as HTML
Then after next start of Amibroker you can re-import it by open New Analysis and go to File -> Import HTML
If you want to export to Excel then you can do it directly by right-clicking the Optimization result list and choosing 'Select all',  copying the result list and directly pasting it into Excel.
參與人數 2金錢 +7 收起 理由
kilroy + 5 按一個讚!
acerman + 2 按一個讚!
發表於 12-11-16 04:28 | 顯示全部樓層
Or use OLE
  1. AB = new ActiveXObject( "Broker.Application" ); // creates AmiBroker object
  2. try
  3. {
  4.   NewA = AB.AnalysisDocs.Open( "C:\\Program Files\\AmiBroker\\APX\\Test.apx" ); // opens given analysis project file
  5.   // NewA represents the instance of New Analysis document/window
  6.   if ( NewA )
  7.   {
  8.     NewA.Run( 4 ); // starts analysis (asynchronous - returns immediatelly
  9.       // (0-scan, 1- exploration, 2- portfolio backtest, 3- Individual Backtest, 4- optimization, 5- Individual Optimization (not supported yet), 6-walk forward)
  10.     while ( NewA.IsBusy ) WScript.Sleep( 500 ); // wait for completion
  11.     NewA.Export( "test.html" ); // exporting results
  12.     WScript.echo( "Completed" );
  13.     NewA.Close(); // closing analysis window
  14.   }
  15. }
  16. catch ( exc )
  17. {
  18.   WScript.echo( "Exception: " + exc.message ); // display error that may occur
  19. }
 樓主| 發表於 12-11-19 01:57 | 顯示全部樓層
獲益良多  非常謝謝^^
發表於 12-12-16 17:33 | 顯示全部樓層
joshsmi 發表於 12-11-16 04:25
十分謝謝大大熱心分享! ^_^
GMT+8, 26-11-5 07:53
