查看: 16003|回復: 9
Multicharts 8.5 Beta 1發佈了
發表於 12-11-19 16:24 | 顯示全部樓層 |閱讀模式
事隔半年左右就出8.5 Beta1了
Multicharts 8.5 Beta1 32位元
Multicharts 8.5 Beta1 64位元
TrendRover + 2 按一個讚!
googleandy + 2 謝謝,感恩!
發表於 12-11-19 19:49 | 顯示全部樓層
多謝大大的分享喔
發表於 12-11-19 17:33 | 顯示全部樓層
多了什麼功能嗎?
觀望一下在更新好了。
發表於 12-11-19 17:44 | 顯示全部樓層
對軟體習慣的速度  還趕不上更新的速度
俺還在用7.4哩
發表於 12-11-19 19:47 | 顯示全部樓層
謝謝大大提供資訊
 樓主| 發表於 12-11-20 00:11 | 顯示全部樓層
本帖最後由 paf 於 12-11-20 00:12 編輯
winfast48 發表於 12-11-19 17:33
多了什麼功能嗎?
觀望一下在更新好了。
在官網首頁最上方
就有一行 MultiCharts 8.5 Beta 1 features all-new Volume Delta and Cumulative Delta chart types.
似乎就是這次改版的最大重點~
發表於 12-11-20 06:06 | 顯示全部樓層
又出現一種K線喔
發表於 12-11-20 06:07 | 顯示全部樓層
Volume Delta and Cumulative Delta chart types. 的重點是在哪呢
發表於 13-2-6 10:05 | 顯示全部樓層
8.5 RC 版發布了
下載點
8.5 32bit
8.5 64bit
What's New
Contact Support
http://www.multicharts.com/support/contact/
Online Wiki – Complete Information about MultiCharts
http://www.multicharts.com/trading-software/index.php/Main_Page
Report Bugs and Request Features in the Project Management System - http://www.multicharts.com/pm/
NEW FEATURES
FREE 30 days of real-time futures, index and FX data from DTN IQFeed
DTN IQFeed, one of the best feeds available for MultiCharts, now offers a free 30 day trial for any MultiCharts user, no credit card required. The startup wizard now gives you an option to fill out a simple form and get instant access to real-time futures, index and FX data without leaving MultiCharts. There are also new built-in workspaces that automatically give you most popular IQFeed symbols. DTN IQFeed data features:
-       True tick-by-tick streaming data and ability to watch 500 symbols at a time.
-       Real-time data from CME, CBOT, NYMEX, COMEX, ICE and FX.
-       Delayed data on stocks, indexes and international futures exchanges, such as Eurex, Simex, NYSE Liffe.
-       Deep historical tick (120 days), minute (5+ years) and daily data (10+ years) with backadjusted continuous futures charts.
Volume Delta chart type
Volume Delta (comparable to FootPrint®* chart) chart type is now available. This chart lets you see how many trades were done at ask and bid on each price level within a bar. The bars look like boxes with appropriate numbers displayed within them. There are two calculation methods: “Ask Traded vs Bid Traded”and“Up Ticks vs Down Ticks”.Three display options available: “Bid and Ask Volume”, “Total Volume”, and “Delta (Ask – Bid Volume)”. You can also the numbers as percent.
Complete Volume Delta description – http://www.multicharts.com/trading-software/index.php/Volume_Delta
Cumulative Delta (also known as CD chart) chart type is now available. Cumulative Delta is based on direction-based volume accumulation, not on price. The scale of the chart shows volume and bars represent accumulated delta (buy – sell) of the volume for specified resolution. In trending markets CD will move into positive or negative values, while it will oscillate around zero in non-trending markets.
Complete Cumulative Delta description – http://www.multicharts.com/trading-software/index.php/Cumulative_Delta
Volume Profile
Volume Profile (also known as VP) was complete rethought and built from the ground up. It’s now an advanced chart attribute with multiple options and display methods, and it’s available on every chart. Volume Profile tracks trading activity volume across different price levels and varying time length.
Complete Volume Profile description – http://www.multicharts.com/trading-software/index.php/Volume_Profile
TimePriceOpportunity (TPO) indicator available
TimePriceOpportunity (comparable to MarketProfile®** indicator) is an indicator that is similar to Volume Profile, but typically with slightly different price levels of importance. Letters are used to symbolize time brackets. The trading day is divided into 30 minute periods, called Time Price Opportunities, or TPO’s. Each time the market trades at a price that hasn’t occurred in a prior TPO, a letter is marked at that price. One of the potential uses is to help identify prices that have form resistance and support levels.
More info and indicator source here – http://www.multicharts.com/discussion/viewtopic.php?f=5&t=10872
Flexible Commission Rules
You can now add flexible commission rules to make backtesting more precise. With varying combinations, it’s now possible to account for virtually any commission setup around the globe. Commissions can be set though a new window in Strategy Properties. Rule options include calculating commission in real-time, after every trade or once every day, resetting volume counter after every trade/monthly, commission limits and per Trade/Contract modes in dollar amounts and percent.
Complete Commissions description – http://www.multicharts.com/trading-software/index.php/Commissions
Choose your currency for calculating PnL
You can now see PnL calculated and displayed in the currency of your choice. If you want to see PnL in JPY for instance, changes will be seen on charts, DOM and in the Order and Position Tracker. Current exchange rates are continuously pulled from our FX servers, so there’s no need to enter the conversion rate manually.
Order and Position Tracker improvements
“Market Position History at Broker” tab was added to OPT. It tracks how MP changed over time directly on the account. This helps resolve any questions as to why an order could have been sent for X contracts, but the MP changed for Y contracts.
“Alerts” tab was added to OPT. It tracks and displays all alerts generated by scripts. Essentially, it provides a complete history of all alerts generated by scripts, so you don’t need to worry about missing an alert.
“Accounts” tab in Order and Position Tracker can now be shown in any user-defined currency.
Second-by-second playback for 64-bit MultiCharts
Second-by-second mode for Data Playback was added to 64-bit MultiCharts. In global mode the tick charts do not currently update in-sync with time-based charts.
AvaTrade data feed and broker added
AvaTrade (formerly AvaFX) data feed and broker were added. AvaTrade is broker that is well known around the world. They currently offer Forex trading and quotes, but plan to integrate futures as well.
WeBank data feed and broker added
WeBank was established in 1999 and is one of the leading Italian banks and online brokerages with over 80,000 clients.
Secure Socket Layer (SSL) support for Email Alerts in indicators
Added Secure Socket Layer (SSL) support to email alerts. This means you can now use most modern email providers for email alerts, such as Gmail.
Change save locations for databases, studies, logs and file cache
Users can now define preferred paths and locations for MultiCharts’ databases, studies, logs and file cache. This may be especially useful if you have an SSD drive or not enough permissions in certain shared environments.
QuickAccess button
Quick access dropdown was added to the chart for recently used symbols and resolutions. You can now quickly switch between symbols and resolution directly from the Status Line of the chart.
Exit Strategy behavior changed
Exit strategy behavior was changed:
1) Strategies that were applied to active orders no longer “jump” onto the active position after the parent order was filled. They remain active and keep protecting orders that were generated by the parent order.
2) If an exit strategy is applied to the open position then everything works almost like before – position changes are monitored, but there’s a minor nuance. When calculating reaction to position changes it’s taken into account that there are strategies applied to filled orders and their effect on the overall position. In other words, strategies applied to the position protect the remainder that is not protected by strategies applied to individual orders.
3) Strategies applied to positions and strategies applied to orders will be visually different on both on the chart and in the DOM.
More info here - http://www.multicharts.com/discussion/viewtopic.php?f=19&t=11446
4) If a position was opened by an order that has an exit strategy attached from a flat position, then this strategy is applied to the entire position and “protects” it.
Other features
  • Added a new ScrollToBar function, which centers      the chart on the specified bar – function void ScrollToBar( int DataN, int      BarN).
  • New service window (permanently attachable, like      the Data Window) was added for the Scanner.
  • Symbol Linking is now available in the Depth of      Market (DOM).
  • Ability to draw a horizontal or vertical      TrendLine when holding down CTRL. More info here – http://www.multicharts.com/pm/viewissue.php?issue_no=MC-960.
  • CQG indexes are now supported.
  • Now only orders that were actually modified are      changed in OCO groups (either emulated or native), as opposed to previous      behavior of updating all orders. More info here – http://www.multicharts.com/discussion/viewtopic.php?f=1&t=8810&p=51029#p50682.
  • Timeout can now be specified manually in the      broker profile for Interactive Brokers. This helps if you get the      following message from IB: “Didn’t receive final status for the      order”, and you’d like to increase the waiting time.
  • New status was added for order that were NOT      confirmed by the user – “Ignored”.
  • Compact mode for DOM window now shows Entry Price      along with size of the position.
  • Added resolution for exotic chart types to the      status line on charts.
  • Added Sessions category to the HotKeys menu with      two menu choices: “Use Default Session” and “Use 24/7      Session”. More info here – http://www.multicharts.com/discussion/viewtopic.php?f=1&t=10639#p53511.
  • Open PnL for Interactive Brokers is now      calculated using mapping.
  • It’s now possible to sort by Error column field      to reduce time looking for errors.
  • Separate Trading Limit Account is now supported      through Interactive Brokers profile.
  • Proprietary Trading Group account support was      added for Interactive Brokers profile.
  • Previous optimization report with results can now      be viewed if new optimization was cancelled. More info here -http://www.multicharts.com/discussion/viewtopic.php?f=1&t=11693.
  • When “Generate a new tick if Total Volume      changes” option is turned on for Interactive Brokers data feed, the      first tick of the session is no longer generated if opening price hasn’t      arrived yet.
  • Autotrading is now automatically turned on in      workspaces in which it was enabled during shutdown. The user will be      prompted for confirmation prior to start of autotrading, This is      convenient for workspaces that have multiple charts enabled for      autotrading.
  • DOM in Dynamic mode is now always centered on the      average price between latest ask and bid prices, and not on the Last      price.
  • New button “Turn AutoTrading Off” was      added on the Order Confirmation dialog.
  • Anchor button was added to lock in the last date      in the “From-To” range in the Strategy Properties window.
  • Custom Futures now supports symbols with the      following format – “NIFTY10APRFUT” using Interactive Brokers      data provider.
  • Optimization speed was increased. More info here      - http://www.multicharts.com/discussion/viewtopic.php?f=19&t=10710.
  • New upgraded API is used for LMAX data feed and      broker.
  • One contract for LMAX broker is now a Micro lot.
  • Ask/Bid with volume of AskSize/BidSize equal to      zero or not equal to -1 are now filtered.
  • XAUUSDO.COMP and XAGUSDO.COMP (Precious Metals)      symbols were added to the Symbol Search for IQFeed. More info here -http://www.multicharts.com/discussion/viewtopic.php?f=19&t=11011&sid=0fbdc9d10ec47b3c29383a80194873f0#p54393
  • Attempts to reconnect      to ZenFire now stop after receiving error: “access denied”.
  • Added an option to the “Preferences ->      Trading” menu to use EntryPrice based on order fill price for      semi-automated strategies. More info here -http://www.multicharts.com/discussion/viewtopic.php?f=1&t=10238#p54354/.
  • Added an option to “Enable access to      intra-bar time for calculation in Intra-Bar Order Generation mode” in      Strategy Properties -> Backtesting tab.
  • Optimization dialog window now shows current best      results during optimization.
  • Optimization settings window was improved – it’s      now possible to exclude certain inputs and current input and step values      are displayed.
  • Optimization Report now stays with its chart      through any chart copy or workspace save operations after being generated.      More info here -http://www.multicharts.com/pm/viewissue.php?issue_no=MC-130 and here http://www.multicharts.com/discussion/viewtopic.php?f=1&t=6620.
  • Improved display speed of events from AvaTrade,      CQG and MB Trading in Order and Position Tracker.
  • Collect Data feature in QuoteManager no longer      requests historical data, only collects real-time from the moment is was      turned on.
  • Added a new bar style called “High-Low”      for regular bars, Renko and Cumulative Delta.
  • Service (attachable) Scanner is now shown on the      right by default and has 25 lines.
  • Added a clearer description for “Account      Size Required” in Performance Reports.
  • Added options to enable/disable Instrument      Dropdown and Resolution Dropdown menus (Chart options -> Status bar).
  • Added a column in Format Objects to display the      date if the “From – To” has been anchored in Strategy      Properties.
  • Improved conflict resolution behavior when      importing QMD archives into the QuoteManager.
  • Updated session templates and symbol roots for      CME Globex since their hours of operation changed from 3:15 pm CT to 4:15      pm CT.
  • Added Lock Drawing command to HotKeys.
  • Improved Manual and Strategy Performance Reports.
  • Added a warning message that reads “Maximum      capacity of 9500 active GDI objects reached. New windows cannot be      created. Close some windows and try again.”
  • Added a clear error message: “Impossible to      switch Data Server mode. Close all charts, scanners and QuoteManager      windows. If you also have a service scanner (View > Show Scanner Window      is enabled), then delete all symbols from this window. Then try to switch the Data Server mode again.”
  • CQG API – now can only use CQG API 4.05.101.
  • Symbols now load sequentially for Barchart data      feed.
  • Added a Symbol Dictionary for Bloomberg (MC PRO      only).
  • Updated Symbol Search for Bloomberg API (MC PRO      only).
  • Added a Settings dialog to Bloomberg data feed to      switch between “Local” and “Exchange” times (MC PRO      only).
BUGS FIXED
Charting/Data Handling
  • Symbol Dictionary      settings were updated for @BO#, @S# and @W# (Grains Futures, IQFeed). More      info here -http://www.multicharts.com/discussion/viewtopic.php?f=1&t=11068
  • Market Depth on Chart      indicator is now limited to 40 levels.
  • UpVolume and DownVolume      were shown incorrectly for ZenFire data feed.
  • Daily bar was not      closed at the end of the session, even when the timeout expired.
  • Problem when using data      merging between OpenECry data feed and ZenFire Local Sim broker profile –      ask/bid prices weren’t showing up.
  • No real-time data for      CQG if time zone chosen for chart is GMT+5:30.
  • MultiCharts 8 could not      read data from a database created in MultiCharts 6.
  • Data could not be      received for symbol TEF, category CFD, SMART exchange.
  • Fixed backfilling on      charts with Custom Futures symbols from Interactive Brokers.
  • Sometimes impossible to      create charts for expired contracts for CQG.
  • Not all charts are      plotted when using ASCII Mapping data feed in Offline mode on MultiCharts      64-bit.
  • Custom Futures      contracts for OpenECry didn’t work when Online server mode is chosen.
  • Fixed incorrect      historical volume values from IQFeed. More info here - http://www.multicharts.com/discussion/viewtopic.php?f=1&t=10518&p=51767#p51461.
  • Root values for certain      Quik futures automatically changed to lowercase in Symbol Dictionary and      Edit Instrument, rendering them unusable.
  • Symbol Dictionary for      some data providers showed incorrect setting for the ZB symbol root.
  • Renko bars had      incorrect volume in real-time.
  • Historical symbol was      not displayed when Data Merging was enabled on the chart.
  • Drawing coordinates      would shift during scaling if the latest drawing coordinate was placed      beyond the last bar.
  • Drawings with Snap Mode      enabled sometimes did not connect to actual High and Low values of the      bar. More info here -http://www.multicharts.com/pm/viewissue.php?issue_no=MC-988.
  • Fixed an issue so that      if a single volume column is present in an ASCII file it’s correctly      recognized as “Volume” as opposed to “Down Volume”.      More info here - http://www.multicharts.com/discussion/viewtopic.php?f=1&t=11507&p=56687.
  • It wasn’t always possible      to add symbols $TICK and $TNX symbols from Barchart data feed.
  • Symbols are present in      workspaces while not shown in Scanner windows.
  • Ticks sometimes arrived      with zero volume in realtime for Futures contracts from CQG data feed.
  • Trend lines moved when      background dragging was used on a chart.
  • Weekly resolution chart      for QUIK data feed was displayed incorrectly.
  • If a minute chart with      an active broker profile was copied and pasted after a reload then data      was different on the new chart.
  • Stock Options with      fractional Strike prices didn’t add correctly to QuoteManager
  • Couldn’t add the symbol      GCH3 from Barchart data feed when searching by GC or using an asterisk in      QuoteManager.
  • Expert Commentary      window didn’t support data format supported in Windows. More info here      - http://www.multicharts.com/discussion/viewtopic.php?f=1&t=11726&p=57846#p57846.
  • If Box Size was written      in regular fractions it changed to a decimal fraction in the status line      for Renko charts after copying and pasting a chart.
  • Collect Data didn’t      work for all LMAX symbols through their data feed.
  • Plots without values      were taking into account when calculating the price scale.
  • Real-time was not working      for TradeStation data feed.
  • Step Count in      Optimization dialog showed incorrect values of local currency setting on      the machine use a period as a separator. More info here -http://www.multicharts.com/discussion/viewtopic.php?f=1&t=11659&p=57434#p57440
  • Could not chart the      EUR.CHN symbol from Interactive Brokers, it gave the “No Security      definition was found” message. More info here -http://www.multicharts.com/discussion/viewtopic.php?f=1&t=11635&p=57299#p57299
  • Chart blinked while      indicator plots were refreshed.
Trading
  • Situation when orders      are canceled by the broker through ZenFire profile (i.e. there is no      callback ID through the API) were not handled correctly.
  • Sometimes exit      strategies with enabled “auto-apply” did not work the first time      after connecting a broker profile.
  • Market Position did not      arrive for Trading Technologies broker profile.
  • Orders could not be      sent for symbol TEF, category CFD, SMART exchange.
  • Stop order price was      incorrectly shown in MultiCharts for MB Trading broker profile if the      order was sent from another application.
  • Orders could modify      incorrectly when scaling was changed on the chart. More info here -http://www.multicharts.com/discussion/viewtopic.php?f=19&t=11057.
  • PnL didn’t change when      trading through Rithmic(ZenFire) Local Sim with Price Scale = 1/1000000
  • Stop order that could      not be filled was filled at the Trading Technologies broker after changing      Stop-Limit order to a Limit.
  • Manual inactive orders      didn’t always get placed at the price specified by the user.
  • Emulation of OCO exit      orders did not work. One order was not cancelled when other was filled.
  • Problems if orders were      sent to Trading Technologies with an incorrect account number.
  • Account information did      not update if there was no trading activity for the OpenECry broker      profile.
  • Limit orders did not      fill on the last tick of the bar (1 Tick Magnifier). More info here – http://www.multicharts.com/discussion/viewtopic.php?f=1&t=10708.
  • Price orders were being      sent right after turning on autotrading in-between sessions.
  • Sometimes impossible to      place orders after creating a chart for CQG.
  • Orders were placed      again when they shouldn’t have after calculating on several price series.
  • Orders were filled at      unusual prices on ZenFire Local Sim after 4 pm.
  • Quantity Filled in      Order and Position Tracker was incorrectly displayed if a partial fill      occurred during a connection loss.
  • Fixed an issue      when using several broker profiles for Interactive Brokers at the same      time.
  • Removed “FIX Tag      77 = C” from Trading Technologies trading profile to improve      performance.
  • Problems when trading      CFDs through the IB account.
  • It was sometimes      impossible to move exit strategies around. More info here -http://www.multicharts.com/discussion/viewtopic.php?f=1&t=11339&p=56059#p56031
  • Manual exit order is no      longer cancelled when disconnecting broker profile if it’s the only one in      its emulated OCO group. This pertains to brokers that don’t support OCO,      so it has to be emulated locally in MC.
  • Manual orders were      doubled for LMAX broker. More info here -http://www.multicharts.com/discussion/viewtopic.php?f=19&t=11714.
  • OCO-group orders got      unnecessarily replaced too many times.
  • Market orders were      replaced on ZenFire Local Sim frequently.
Scripts/Calculations
  • PlaceMarketOrder can      now send orders when the bar is closed but is recalculated using      RecalcLastBarAfter.
  • Indicator on several      data series stops calculating with the Contract resolution
  • MouseClickCtrlPressed      and MouseClickShiftPressed keywords would not reset after using recalculate,      causing a cyclical lockup of the study. More info here -http://www.multicharts.com/discussion/viewtopic.php?f=1&t=11115.
  • PowerLanguage issue      with MarketDepthOnChart indicator where not all levels would be shown.      More info here -http://www.multicharts.com/pm/viewissue.php?issue_no=MC-1133.
  • Some strategies      calculated fine on individual charts and did not calculate in Portfolio      Backtester.
  • Deadlock when changing      signal status if the Strategy Performance Report is open.
  • Some keywords that      compiled in 7.4 stopped compiling in MultiCharts 8. More info here -http://www.multicharts.com/discussion/viewtopic.php?f=1&t=10849.
  • Incorrect results in      the Max Intraday Drawdown column in the Optimization Report.
  • Plot did not disappear      in the Market Scanner after NoPlot() was executed.
  • ReadOnly studies and      functions were not replaced when importing PLA archives.
  • PosTradeEntryDateTime      keyword returned approximate order generation time instead of accurate      order fill time.
  • IntrabarOrderGeneration      was incorrectly calculated in some instances.
  • DollarPerTrade defined      the number of contracts for market orders differently in Portfolio      Backtester and on a regular chart.
  • When Slippage or      Commission is enabled in Strategy Properties, “All Trades” field      did not equal the sum of “Long Trades” and “Short      Trades” in the Strategy Performance Report. More info here -http://www.multicharts.com/pm/viewissue.php?issue_no=MC-1131.
  • PosTradeIsOpen and      PosTradeIsLong keywords did not work as was described in the Help file.      More info here -http://www.multicharts.com/discussion/viewtopic.php?f=1&t=10743.
  • Issues with average      fill price and calculation of Strategy Performance Report.
  • Sometimes maxbarsback      value did not influence “crosses over” calculation. More info      here – http://www.multicharts.com/discussion/viewtopic.php?f=1&t=10593#p51941.
  • Dependent functions      were exported in PowerLanguageEditor even when the option not to export      was chosen.
  • Indicator values were      not shown in the Scanner under certain conditions.
  • NoPlot keyword removed      the drawing from the chart, but did not rollback the last value in Status      Line. More info here -http://www.multicharts.com/pm/viewissue.php?issue_no=MC-116.
  • Values in Optimization      Report did not match values in the Strategy Report when using      posttradeprofit.
  • Price orders during Bar      Magnifier testing didn’t execute on correct prices if      IntrabarOrderGeneration was turned off.
  • Strategies that use      “next bar” keywords didn’t calculate when BarMagnifier was      enabled (OHLC values weren’t taken from the correct bar).
  • Assert and exception      when trying to optimize a study that has fractional inputs.
Stability/Performance
  • PowerLanguage studies      did not compile in MultiCharts when used with Windows 8.
  • Assert in study_runner      when using an indicator on several data series stops calculating with the      Contract resolution.
  • Exception in      MultiCharts64.exe when compiling applied study.
  • Exception when trying      to send an email alert.
  • MultiCharts processes      would sometimes hang when closing workspaces or the application.
  • Exception in      ATCenterServer when folder structure with Order and Position Tracker logs      is changed.
  • Exception when      switching between connected broker profiles.
  • Memory leak in      tsServer.exe when creating a new tick chart for a new symbol or doing a      large reload for LMAX data feed.
  • Lockup when trading      from several workspaces through several instances.
  • Exception when closing      the application in TradingServer.
  • Deadlock when turning      off trading (Sync AT + Show Initial Entry Position always + active RT from      broker).
  • Assert when charting a      certain kind of Custom Futures contract.
  • Assert and data did not      show on chart when new data was added to an ASCII file that was mapped.
  • Exception if connection      was lost during a historical data request.
  • Exception in      PowerLanguageEditor when importing studies from several files at the same      time.
  • Assert when installing      MultiCharts onto a Korean Windows operating system.
  • Exception when closing      the session with a timeout under certain conditions.
  • Exception in      ScannerManager.dll when closing MultiCharts with certain workspaces and      databases.
  • Assert and exception      when сlosing workspace with      DOM window for which Select Font and Format Colors dialogs were open.
  • Exception when closing MultiCharts.
  • Exception and real-time      not working for GlobalServer data feed. More info here - http://www.multicharts.com/discussion/viewtopic.php?f=1&t=11659&sid=852d1a200814cae7d06454062c568d91#p57416.
  • Deadlock if hidden OPT      was active and autotrading was enabled on many charts.
Usability/Visual
  • Corrected behavior of      Visual Order option – it doesn’t affect scale anymore when enabled. More      info here -http://www.multicharts.com/discussion/viewtopic.php?f=1&t=10461.
  • Values for inputs that      weren’t optimized during optimization now keep their old value.
  • Coordinates of drawings      related to indicators calculated on Custom Futures contracts would change      when they shouldn’t have. More info here - http://www.multicharts.com/discussion/viewtopic.php?f=1&p=54264#p54264.
  • Visually empty Market      Scanner windows added many symbols to the QuoteManager database.
  • Windows size was wrong      when copying and pasting a window from another monitor.
  • Orders were visually      doubled in Order and Position Tracker if two broker profiles were created      and used for Trading Technologies with the same login but different      accounts.
  • Pause button was not      always visible when Trade Panel was in Compact Mode. More info here – http://www.multicharts.com/pm/viewissue.php?issue_no=MC-1055.
  • Row numbers after      choosing Show Row Selector in Market Scanner did not serialize properly.
  • Commission values were      not saved when exporting strategy reports in XML format.
  • Slippage,      InitialCapital and InterestRatevalues were saved incorrectly when      exporting strategy reports in XML format.
  • Visual defect when      drawing a bar in a price series located above a session break. More info      here -http://www.multicharts.com/discussion/viewtopic.php?f=1&t=10447&sid=e7079a8171ad8ffe68c6f8771cb913b7#p51319
  • Icon centering on Chart      Analysis toolbar was off after restarting the platform. More info here -http://www.multicharts.com/discussion/viewtopic.php?f=1&t=10518#p52225.
  • Sometimes part of a      detached window was not visible.
  • Session Break lines      appeared automatically when Bid&Ask indicator was applied to the      chart. More info here -http://www.multicharts.com/discussion/viewtopic.php?f=18&t=9500#p50580.
  • Incorrect      “Ready” status was sometimes displayed for ReadOnly indicators.
  • Charts did not always      return to original position after being minimized and maximized.
  • Fixed error with CSV      export to Excel 2003 (now export is done in UTF-16LE format).
  • The “index”      word was removed from Symbol Search for Bloomberg when searching through      the Index tab.
  • Issues regarding      connecting MB Trading on application startup and when plotting DOM.
  • Time In Force and      Quantity would sometimes be unsaved when copying and pasting a chart      within the same workspace.
  • Order Confirmation      window on one chart would sometimes cause another chart to reject orders.      More info here -http://www.multicharts.com/pm/viewissue.php?issue_no=MC-1128.
  • Color schemes were      mixed up for Candlesticks and Hollow Candlesticks for the Neutral      component. More info here -http://www.multicharts.com/discussion/viewtopic.php?f=1&t=10654.
  • Time in the Status Line      was incorrectly displayed for Futures contracts for LMAX data feed.
  • Chart Shift      “Bars” value was not saved in the workspace.
  • Attachable DOM window      sometimes did not show real-time for CQG symbols.
  • XML reports created by      Strategy Performance Reports could not be opened in some other programs.
  • Visual artifacts      remained on screen when adding drawings with Snap Mode enabled. More info      here -http://www.multicharts.com/discussion/viewtopic.php?f=19&t=10703#p52511
  • StartValue and EndValue      in optimization settings did not match CurrentValue by default.
  • Option “Status      line – Enable MultiLine Mode” now carries OHLCV values over to the      next line if it doesn’t fit on the chart.
  • When connecting to      Halifax TWS the connection prompt dialog was not auto-accepted.
  • Fixed Ctrl-Z shortcut      in PowerLanguageEditor.
  • It was sometimes      impossible to open PowerLanguageEditor from inside MultiCharts. More info      here -http://www.multicharts.com/discussion/viewtopic.php?f=1&t=11339&p=56061#p56033
  • Very small values for      Slippage and Initial Capital in the Strategy Properties dialog were      changed to the exponential format, i.e. “1e-00X”
  • Open PnL on the      Strategy Position tab in Order and Position Tracker was displayed with an incorrect      currency symbol for LMAX broker.
  • Equity Curve Detailed      Long and Equity Curve Detailed Short charts were not exported to Excel      from Strategy Performance Report along with other information. More info      here – http://www.multicharts.com/pm/viewissue.php?issue_no=MC-1206.
發表於 13-2-6 10:22 | 顯示全部樓層
我對7.0都還沒熟悉呢
不容易上手 上了手就很方便
GMT+8, 26-11-14 21:39
