樓主: richdad
那一位好心人可以教我開戶AMP clearing (500 USD)感恩
發表於 13-5-3 20:58 | 顯示全部樓層
richdad 發表於 13-5-3 20:41
有~剛有上線問他了~大感謝~
英文不錯唷!!!!
 樓主| 發表於 13-5-7 18:27 | 顯示全部樓層
roder 發表於 13-4-30 22:22
這位大大...你的開戶應該還沒完成喔,之前我開過AMP,從你第一張圖來看你還未收到Your Application has bee ...
感謝R大~有問題在向您請教~
 樓主| 發表於 13-5-9 07:28 | 顯示全部樓層
casey 發表於 13-5-3 20:58
英文不錯唷!!!!
C大安安~
我已寄護照及英文水費單給AMP,他們發了二封信給我。
第一封主旨:Your Application has been approved
Account is opened for XXXXXX (XXXXX)
Simply follow the funding instruction provided in the link below.
http:/www.ampclearing.com/funding_instructions.html
1.是不是叫我去電匯?FOR RURTHER CREDIT TO及TRADING ACCOUNT NUMBER填寫好。是嘛?
第二封主旨:An application is pending salesman and commission setup
發表於 13-5-9 08:23 | 顯示全部樓層
richdad 發表於 13-5-9 07:28
C大安安~
第一封主旨:Your Application has been a ...
Hello
是的。可以去電匯嘍~~~~
發表於 13-5-9 08:34 | 顯示全部樓層
越來越多人去挑戰阿兜ㄚ, 讚喔
發表於 13-5-9 08:48 | 顯示全部樓層
CQG提供給給AMP 客戶的新服務~~~~~
《AMP Futures is now offering our customers Colocation for only $99.00 per month》
CQG has created AMP a Custom Colocation Environment via Point-to-Point Fiber Connection to CQG Exchange Gateway
Dedicated Virtual Machine Specs:
(4 GB Ram, 1 Xeon Core (3.8ghz Turbo), 100GB disk, Windows Server 2012)
·       No Activation/Installation Fees
·       No Monthly Internet/Bandwidth Fees
Price only $99.00 per month!  Paid via your existing AMP trading account.
This service is only being offered to AMP customers - limited supply - 100 VMs currently available for instant set up.
If you would like to set up your own Colo VM - please follow these simple steps:
Log into your customer portal:  https://portal.ampclearing.com/account/login.aspx
Under "Platform Setup" tab - go to platform set up - then on the right hand side click - "Request Colocation Setup" and follow the steps.
After submitting this request, you will receive an email with your dedicated VM log in credentials.
We are excited to offer this service to our customers - Please call the 24 hour help desk if you need assistance:  312 893 6400 ext. 1 or email support@ampfutures.com
Happy Trading!
發表於 13-5-9 09:56 | 顯示全部樓層
這個價錢,如果是CQG 自己的colo,那就很好了。反正 AMP 無論 data 或是 trade routing 都是經過CQG, 剩下的就是CQG 到exchange, 那就是’聽天由命‘。
可惜沒有’trial'.
Ray-Ray + 2 感謝分享~b大整體研究非常扎實呢!!.
 樓主| 發表於 13-5-9 18:32 | 顯示全部樓層
casey 發表於 13-5-9 08:23
Hello
是的。可以去電匯嘍~~~~
3QQQQQQQQQQQQQQQ
Ray-Ray + 2 按一個讚
GMT+8, 26-11-18 12:47
