查看: 6627|回復: 17
程式交易演算法已經可以取代華爾街傳統直覺交易
發表於 13-7-23 08:49 | 顯示全部樓層 |閱讀模式
http://www.forbes.com/sites/gregsatell/2013/07/22/why-nate-silver-matters/
文中提到
Automating Patterns
Ria Persad is one of those people born with extraordinary gifts.  She started her research at the Jet Propulsion Laboratory when she was 12, began taking courses at Harvard at 14 and worked at the legendary Institute for Advanced Study, before the age of 20.  She also performs as a concert pianist under her married name, Ria Carlo.
In an earlier age, she would most likely be relegated to academia, where she would spend her days writing arcane formulas on a blackboard that only a handful of people in the world could understand.  Today, however, she runs a thriving business, Statweather, which consults for the energy trading industry.
Persad compares her work to how algorithmic trading has replaced intuition on Wall Street  and says, “The program—not a human—does the pattern recognition, the bias and error adjustments of models, the tracking, and makes the “judgment call” based upon the most dynamically optimal combination of models.”
In other words, she’s not like your friendly neighborhood weatherman trying to predict if you should take your umbrella with you today or not, but uses over a century of data to determine weather patterns months in advance and her accuracy is 74%, nearly double what conventional methods achieve.
She also notes that, much like journalists at the dawn of the digital age, traditional meteorologists see her automated methods as a threat.  No surprise there.
Ria Persad 發明的交易演算法已經可以取代華爾街傳統直覺交易。
發表於 13-7-23 10:12 | 顯示全部樓層
自動模式
利雅Persad出生的人具有非凡的禮物之一。她開始了她在噴氣推進實驗室的研究,當她12歲時,14開始在哈佛的課程,並在富有傳奇色彩研究所的高級研究工作,才20歲。她也執 ​​行一個音樂會鋼琴家在她婚後的名字,利雅卡羅。
在較早的年齡,她將最有可能被降級到學術界,在那裡她將度過她的日子寫在黑板上的晦澀難懂的公式,只有極少數的人在世界上可以理解。然而,今天,她運行一個繁榮的商業,Statweather,能源交易行業諮詢
Persad比較算法交易如何已經取代了華爾街上的直覺,並說,“程序不是一個人做模式識別,她的工作。偏見和錯誤的調整模型,跟踪,並使得“判斷調用”根據車型的最動態的最佳組合。“
換句話說,她是不喜歡你的友好鄰里氣象試圖預測,如果你要採取你的傘與你今天或沒有,但使用了一個多世紀的數據,以確定天氣模式提前幾個月,她的準確度為74%,增長近一倍常規方法實現。
她還指出,就像記者在數字化時代的曙光,傳統氣象學家看到她的自動化方法,是一種威脅。這並不奇怪。
by 亂七八糟google chrome翻譯
發表於 13-7-23 10:40 | 顯示全部樓層
如果交易演算法已經可以取代華爾街傳統直覺交易
华尔街的证券商为什么没有将所有的交易员fire?
这样不是可以省很多钱吗?
發表於 13-7-23 11:42 | 顯示全部樓層
LTCM開始的前幾年也是所向無敵,但是最後人的貪婪還是發揮了他的作用。
參與人數 3金錢 +6 收起 理由
winforjs + 2 按一個讚
jodo + 2 好文章,我推薦
CatterFly + 2 !!
 樓主| 發表於 13-7-23 12:04 | 顯示全部樓層
閒人英郎 發表於 13-7-23 10:40
这样不是可 ...
只是轉貼,不歡迎戰文~
 樓主| 發表於 13-7-23 12:08 | 顯示全部樓層
comewish 發表於 13-7-23 11:42
何不看看詹姆斯.西蒙斯創辦的「文藝復興科技公司」(Renaissance Technologies Corp.)呢~
發表於 13-7-23 12:28 | 顯示全部樓層
本帖最後由 閒人英郎 於 13-7-23 13:16 編輯
philipz 發表於 13-7-23 12:04
只是轉貼,不歡迎戰文~
不同意你的说法!
只是表达不同的意见
这不是战文!
如果这样回文也不可以
你干脆不要发文算了
 樓主| 發表於 13-7-23 12:50 | 顯示全部樓層
本帖最後由 philipz 於 13-7-23 12:51 編輯
閒人英郎 發表於 13-7-23 12:28
不同意你的说法!
只是表达不同的意见
这不是战文!
抱歉~誤會一場!
看到簡體字,以為是來亂的。
個人沒在華爾街上班過,所以不知道為何不FIRE掉交易員?
發表於 13-7-23 13:15 | 顯示全部樓層
philipz 發表於 13-7-23 12:50
抱歉~誤會一場!
看到簡體字,以為是來亂的。
不用客气啦
在台北市已经住了40多年
很多论坛大家骂来骂去
尤其大陆论坛更是严重
在coco-in 讨论风气还是算很平和
算是很难得
来这边算是来对了
發表於 13-7-23 13:43 | 顯示全部樓層
coco-in的確是一個素質很高的論壇........
發表於 13-7-23 14:42 | 顯示全部樓層
coco大家語氣平和是因為 有很多神人在此坐鎮啊..........
發表於 13-7-23 23:48 | 顯示全部樓層
COCO的文化真的沒話說~~~
發表於 13-7-23 23:51 | 顯示全部樓層
不同意你的说法!
只是表达不同的意见
这不是战文!
以前也被你的簡體字騙過....
發表於 13-7-25 00:45 | 顯示全部樓層
簡單不代表無效,複雜也不代表有效
Billions+ + 2 就是醬沒錯!XDDDD...(學獅子笑)
jodo + 2 好文章,我推薦
發表於 13-7-25 01:16 | 顯示全部樓層
這些年美國的創新, 美西在矽谷美東在華爾街, 像文中這類有新的交易模型或思維, 就跟科技業的新技術類似, 先不管最後能不能成功或有市場, 還是能吸引機構或新創型基金去評估其潛力.  P 大如果有興趣這方面, 可以多著墨在新思維的策略上, 不用去管開始的績效, 就好像 event-driven 的思維和系統剛開始也沒人會想到現在的狀況.
GMT+8, 26-11-29 20:08
