查看: 3144|回復: 3
[工具] Multicharts 8.7 正式版 (第4版) (20130729) RELEASE
發表於 13-7-30 05:29 | 顯示全部樓層 |閱讀模式
本帖最後由 電腦人 於 13-7-30 06:12 編輯
Multicharts 8.7 正式版 (第4版) 短短29天改了4版 (20130729)
代表之前20130701、20130706、20130716的8.7版本是BETA版嗎?!
真的無言 可以再誇張一點嗎
難道不能用8.8、8.9...來命名嗎
http://www.multicharts.com/downloads/multicharts.8.7.exe          32-BIT 8.7.7570.400
http://www.multicharts.com/downloads/multicharts.8.7.x64.exe    64-BIT 8.7.7569.400
希望TS SUPPORT是採用LIVE UPDATE的方式,而不是每次升級都要重新下載安裝整個程式
發表於 13-7-30 06:07 | 顯示全部樓層
本帖最後由 lantis 於 13-7-30 06:10 編輯
MultiCharts 8.7 Release builds 7570/7569 is a minor upgrade that includes the hot fixes for issues in MultiCharts 8.7 Release reported by our customers.
BUGS FIXED:
•        There was an issue with LMAX broker profile when several profiles were connected simultaneously.
•        PowerLanguage: When the name of an input was changed in a signal applied on a chart and then recompiled, the new name would not be showed up on the chart.
•        Exception came up when trying to re-create a chart with MetaStock minute data.
•        Volume Delta issue: the status provided by a data feed was thrown off in real time. More info here - viewtopic.php?f=1&t=28567#p83842
•        PowerLanguage: The file that had been created by PRINT was blocked even if a study had a status OFF.
•        DOM data was not shown for Korean futures KSU3 (root K200, exch KSE).
•        There were no real-time updates on a chart (mostly related to InteractiveBrokers feed).
•        No data on a chart with an expired future symbol using From_ To_ <today> data range.Cumulative Delta: the values were different when you copied and pasted a chart with OpenECry data.
•        If OpenECry broker profile was connected Manage Broker Profile dialog became locked when one tries to open it.
•        Incorrect Ask /Bid history volume on future symbols from InteractiveBrokers data feed.
•        Fixed issues on manual trading with LMAX broker.
•        Updated the calling of CreateFixOrder and ChangeOrderRate methods in FXCM plugin.
•        CFD symbols from InteractiveBrokers were not ticking on a minute chart if it had been created before trading session hours.
電腦人 + 2 感謝分享
發表於 13-7-30 16:10 | 顯示全部樓層
昏倒
一直更新是........
麻煩測試部門多驗證一下好嗎..
這要是htc 一直更新軟體  早就被幹翻了
 樓主| 發表於 13-7-31 22:38 | 顯示全部樓層
本帖最後由 電腦人 於 13-7-31 23:04 編輯
kidbaby 發表於 13-7-30 16:10
昏倒
一直更新是........
TS SUPPORT的工程師看起來好像沒有下實單的經驗
程式也是寫的一堆BUG...慘
不過更慘的應該是hTC的股價...
GMT+8, 26-11-14 20:40
