查看: 2631|回復: 5
chart 关闭以后还能找到吗
發表於 13-8-2 16:47 | 顯示全部樓層 |閱讀模式
chart不小心关闭了,还能找到恢复吗,不是default chart
發表於 13-8-3 11:11 | 顯示全部樓層
到這兩個資料夾內找找看
C:\Program Files (x86)\AmiBroker\Formulas\Custom
C:\Program Files (x86)\AmiBroker\Formulas\Drag-drop
發表於 13-8-3 13:53 | 顯示全部樓層
要注意Drap-drop folder 是隱形的
發表於 13-8-3 22:20 | 顯示全部樓層
Winson 發表於 13-8-3 13:53
http://www.bleepingcomputer.com/ ... files-in-windows-7/
To make drag&drop folder visible within AmiBroker: Tools>Preferences>AFL and at the bottom check "Show hidden folders". Then it is visible in "Charts" sidebar.
@hangye
I think your old layout is gone once AmiBroker is closed since auto-save is checked by default.
But next time:
Save your chart(s) as a local or global layout and give it a name (or save it as default).
Uncheck Auto-save Layouts in Tools>Preferences>Miscellaneous.
Et voila once you accidentally close a chart or a pane just double click your created layout again and it will be restored. Just create a test layout.
If you make changes to your layout that you wanna keep in the future then you have to right-click your layout and click "Save" every time since auto-save is deactivated.
If you check auto-save layouts in tools-preferences then all layouts are auto-saved before/during shutdown of AmiBroker or during switching to different layouts. So if you don't want auto-save being active then un-check it in Tools>Preferences>Miscellaneous.
 樓主| 發表於 13-8-10 13:12 | 顯示全部樓層
Very thank you Sir
發表於 13-9-7 20:15 | 顯示全部樓層
see page 56 of user's guide..(about layout)
GMT+8, 26-11-5 07:00
