查看: 2782|回復: 9
電腦重灌Amibroker的 data怎麼辦??
發表於 13-9-8 13:36 | 顯示全部樓層 |閱讀模式
請問 如果電腦重灌的話
Amibroker的 data要怎麼保留啊??
把data整個資料夾複製出來,貼回去好像沒有用耶!
thanks
發表於 13-9-8 17:19 | 顯示全部樓層
不會阿,就是Copy 貼上阿,除非您Data路徑,是Copy錯的.
發表於 13-9-8 20:53 | 顯示全部樓層
前後用的AmiBroker的版號一樣嗎?
我印象中5.4版之前的資料格式與後來的不同
若是這種情形,直接複製是沒用的
發表於 13-9-8 21:04 | 顯示全部樓層
若不行就用 export csv file and import csv file
發表於 13-9-8 21:50 | 顯示全部樓層
Could someone please translate the problem into English. Maybe I can help to solve it. The English translator does not work well. Thank you!
As far I as I understand stock009 wants to move a database or just data files from one data base to another? Is that correct?
As to the comment of Sirius, version 5.3 (July 2010) introduced a new data base format. So all versions prior to 5.30 are not able to handle data bases created with versions 5.30 to current version 5.60+. But versions 5.30 and onwards are able to read data bases created with versions prior to 5.30.
發表於 13-9-8 21:57 | 顯示全部樓層
If you want to move a single data file from one data base to another then in the "new" data base you first have to create the symbol within Amibroker. Then you close Amibroker and move the data file from the old data base to the same named folder of the new database. Then re-start AmiBroker again and the data will be visible.
發表於 13-9-8 22:25 | 顯示全部樓層
Use windows script to import ASCII data dosen't need to create the symbol first.
發表於 13-9-9 16:54 | 顯示全部樓層
不會啊,我上個月才買過新電腦,裝好amibroker後,把database目錄copy過去就行啦
電腦人 + 2 感謝分享
 樓主| 發表於 13-9-10 00:35 | 顯示全部樓層
本帖最後由 stock009 於 13-9-10 00:42 編輯
Old HD has bad track
I thought it is very simple.
Copy the AB "Data" folder and past it to the new HD, then all stock data will be migrated.
But I am wrong, it can't work.
This web shows: you should copy the entire contents of AB folder from the old computer
How to migrate AmiBroker to a new computer
http://www.amibroker.com/kb/2010/09/07/how-to-migrate-amibroker-to-a-new-computer/
(OS: All RIGHT. I SEE!)
BUT old HD had died. Everything is gone.
The only way is re-download all data.
Download..........
舊的硬碟用了4年左右
容量是250G,只用了約50G
結果沒想到他就這樣走了~~~
發表於 13-9-10 15:38 | 顯示全部樓層
適時的備份是必要!!!
GMT+8, 26-11-5 08:07
