查看: 4180|回復: 0
AmiBroker 5.71.0 BETA released
發表於 14-3-12 07:56 | 顯示全部樓層 |閱讀模式
http://www.amibroker.com/devlog/2014/03/05/amibroker-5-71-0-beta-released/
A new beta version (5.71.0) of AmiBroker has just been released.
32-bit version:
http://www.amibroker.com/members/bin/ab5710beta.exe
(2 157 048 bytes)
64-bit version:
http://www.amibroker.com/members/bin/AmiBroker5710x64.exe
(9 317 744 bytes)
CHANGES FOR VERSION 5.71.0 (as compared to 5.70.0)
  • AFL: PlotText() now has additional parameter yoffset: PlotText( “text”, x, y, color, bkcolor = colorDefault, yoffset = 0 )
  • AFL: PlotTextSetFont( “text”, “fontname”, pointsize, x, y, color, bkcolor = colorDefault, yoffset = 0 )
  • ASCII importer: now company address can be imported ($ADDRESS  command and new ADDRESS field in the $FORMAT command)
  • ASCII importer: NULL can be specified as date in several date fields such as delisting date, dividend date,etc. This results in date being cleared (unset).
  • Charts: Y-axis grid can now be finer than 0.0001 (#125281) – upto 6 decimal digits (0.000001) are displayed when needed
  • Charts: Null values in Open/Close fields now disable drawing of open/close ticks in the bar chart (PlotOHLC function)
  • UI: Last pane height does not change on window resizing after pane resize anymore.
  • New Analysis: in Windows 7 and 8 the progress of scan/backtest/exploration/optimization is also shown in Windows Taskbar, so it is visible even if AmiBroker window is minimized or covered by other windows
  • New Analysis: Backtest report settings: added option NOT to include Formula in the report (for security purposes)
  • New Analysis: Horizontal scroll bar is refreshed after HTML import
  • Prefs: Currency tab, added option “Trade using FX cash conversion” to handle different ways to calculate profits depending on whenever foreign currency is borrowed or cash actualy exchanged
KNOWN ISSUES:
For more details, instructions and examples how to use new features see the 5.71.0 BETA READ ME
參與人數 3金錢 +9 收起 理由
Winson + 2 按一個讚
enochyu + 2 按一個讚
kilroy + 5 感謝分享
GMT+8, 26-11-5 06:05
