查看: 2514|回復: 2
[工具] AmiBroker 5.73.0 BETA released
發表於 14-3-18 09:35 | 顯示全部樓層 |閱讀模式
咦?晉版真快
March 17, 2014AmiBroker 5.73.0 BETA releasedStability: – Regular BETA, pretty stable, should work fine in most environments
A new beta version (5.73.0) of AmiBroker has just been released.
32-bit version:
http://www.amibroker.com/members/bin/ab5730beta.exe
(2 162 472 bytes)
64-bit version:
http://www.amibroker.com/members/bin/AmiBroker5730x64.exe
(9 322 816 bytes)
CHANGES FOR VERSION 5.73.0 (as compared to 5.72.0)
  • AFL: new GfxSetCoordsMode – rewritten Low-Level Gfx to allow fractional coords and bar/price co-ords mode in addition to pixel
  • AFL: SetOption(“StaticVarAutoSave”, interval ) – added to allow periodical auto-saving of persistent static variables
  • Charts: functions calculating day offset support years > 2038 and are now much faster
  • Charts: Cycle Lines tool has drawn lines in weird places when using very long cycles that resulted in lines being positioned beyond 2038. Fixed.
  • UI: added View->Price chart style->Bars without ticks
  • Change #2534 made in 5.71.0 (allowing Null for Close field in bar chart)  created backward compatiblity issue. Reverted. Instead a new styleBarNoTick introduced that allows to plot bar chart without open/close ticks
  • New Analysis: when Non-exhaustive Optimize was used on symbol without any quotes, UI displayed error and remained disabled and it was not possible to re-run non-exhaustive opt. Fixed.
  • New Analysis: Backtest: Profit figures are color-coded now (negative – red/positive – green)
參與人數 1金錢 +5 收起 理由
kilroy + 5 感謝分享
發表於 14-3-18 13:52 | 顯示全部樓層
Hi,
最近真的頗頻密的~
快到我上一個版本都還沒安裝更新 XD
感謝大大分享
 樓主| 發表於 14-3-19 07:54 | 顯示全部樓層
最近的重點好像是 StaticVar,可以存起來一開就有
GMT+8, 26-11-5 08:09
