查看: 2563|回復: 0
[工具] AmiBroker 5.74.0 BETA released
發表於 14-3-25 12:25 | 顯示全部樓層 |閱讀模式
註:第7項是我的建議
March 24, 2014AmiBroker 5.74.0 BETA releasedStability: – Regular BETA, pretty stable, should work fine in most environments
A new beta version (5.74.0) of AmiBroker has just been released.
32-bit version:
http://www.amibroker.com/members/bin/ab5740beta.exe
(2 172 024 bytes)
64-bit version:
http://www.amibroker.com/members/bin/AmiBroker5740x64.exe
(9 332 232 bytes)
CHANGES FOR VERSION 5.74.0 (as compared to 5.73.0)
  • AFL Editor: Code snippets implemented (phase 1). Code snippet is a small piece of AFL code. It can be inserted by right-clicking in the AFL editor window and choosing “Insert Snippet” menu
  • AFL: Low level GFX: Multi-layering (z-order) implemented. AFL: GfxSetZOrder implemented
  • AFL: Low-level GFX: radius in GfxCircle() function is expressed in “X” units (so it actually draws circle instead of ellipse when coords mode is 1). Additionally you can specify radius in pixels even in co-ords mode = 1. To do so pass radius as NEGATIVE number. Also one pixel is now added to the rounding box so circle is centered at “x,y”.
  • AFL: Low level GFX: in 5.73.0 the pixel co-ordinates were rounded differently than in 5.72 and earlier. Fixed.
  • AFL: Low level GFX: new function GfxGetTextWidth – returns pixel width of specified string. NOTE: it is slow because it has to create temporary DC and font to measure the text. It takes 40us (microseconds), that is about 40 times more than other Gfx functions.
  • AFL: fopen – new parameter: ‘sharing’ decides whenever file is open in sharing mode or not. When sharing is True a file is prepared for subsequent shared reading and writing.
  • UI: Added “Name” (full name) column to Real-time quote window
  • AFL: Implemented user control over Y-axis cursor and tooltips by means of new option chartDisableYAxisCursor, chartDisableTooltips added to SetChartOptions
參與人數 2金錢 +7 收起 理由
Sirius + 2 按一個讚
kilroy + 5 感謝分享
GMT+8, 26-11-5 08:09
