查看: 2469|回復: 0
[工具] AmiBroker 5.75.0 BETA released
發表於 14-4-5 15:44 | 顯示全部樓層 |閱讀模式
AmiBroker 5.75.0 BETA releasedStability: – Regular BETA, pretty stable, should work fine in most environments
A new beta version (5.75.0) of AmiBroker has just been released.
32-bit version:
http://www.amibroker.com/members/bin/ab5750beta.exe
(2 293 544 bytes)
64-bit version:
http://www.amibroker.com/members/bin/AmiBroker5750x64.exe
(9 509 112 bytes)
CHANGES FOR VERSION 5.75.0 (as compared to 5.74.0)
  • Brand new AFL Editor, integrated with MDI structure with many new features
    • line numbering
    • code folding
    • automatic indent
    • indentation markers
    • brace highlighting
    • improved auto-complete
    • in-line error reporting / highlight
  • New Analysis: few messages displayed in modal message box were moved to message bar
  • UI: Active state is tracked separately for each document type (so there is ‘last active chart’ , ‘last active analysis”) to allow functioning of new editor
  • ADK: InfoSite added to the PluginNotification structure (Notify API callback)
  • AFL: Parser tracks position of some operators better so errors and warnings should show locations more precisely (for example Warning 501 points to = sign now)
  • AFL: Parser produces more descriptive “Syntax error, indentifier ‘name’ is undefined ” or “… is not a function” when it encounters a function call for undefined identifier or indentifier that is a variable. Previously it returned ‘syntax error, unexpected ‘(‘
  • UI: removed global user-definable accelerators for Chart/Pageup/down/home/end because they interferred with new AFL editor. Instead chart page/up/down/home/end implemented locally (work only when chart has focus)
GMT+8, 26-11-5 08:09
