查看: 2790|回復: 1
[教學] AB資料庫超過50萬根的方法
發表於 14-4-8 17:43 | 顯示全部樓層 |閱讀模式
With regards to 500 000 bars limit - you can override this limit by adding following registry key
HKEY_CURRENT_USER\Software\TJP\Broker\Settings\MaximumNumberOfBars
enter DWORD value higher than 500000
Then adjust the database settings. Note however that such large amounts are rather recommended for 64-bit version of AB.
發表於 14-4-8 20:54 | 顯示全部樓層
Note however that the default 500000 bars limit is only in regards to real-time plugins.
But i.e. data source: local database doesn't have a default bar limit.
GMT+8, 26-11-5 06:07
