查看: 2697|回復: 2
[工具] AmiBroker 5.76.0 BETA released
發表於 14-4-12 22:10 | 顯示全部樓層 |閱讀模式
最近的更新速度真是快啊,最近重點在Editor
AmiBroker 5.76.0 BETA releasedStability: – Regular BETA, pretty stable, should work fine in most environments
A new beta version (5.76.0) of AmiBroker has just been released.
32-bit version:
http://www.amibroker.com/members/bin/ab5760beta.exe
(2 296 280 bytes)
64-bit version:
http://www.amibroker.com/members/bin/AmiBroker5760x64.exe
(9 520 672 bytes)
CHANGES FOR VERSION 5.76.0 (as compared to 5.75.0)
  • New Editor: Auto-complete has now 3 modes: disabled, on-demand (shows auto complete list when you press Ctrl+SPACE as in old editor) and immediate (auto-complete pops up immediately)
  • New Editor: Auto change case and auto parameter info features can be turned off from the preferences
  • Prefs: Editor page changed: added “Virtual space” checkbox, replaced “Auto-complete” box with 3-way selection radio buttons, removed 2 options that are always on now
  • New Editor: File is saved automatically when it is open in Analysis window and analysis is run
  • UI: leftover and/or user-defined keyboard accelerators for HOME/END/PAGE UP/DOWN, letters and digits without Ctrl/Alt modifier are removed on startup not to interfere with the editor
  • UI: Ctrl+F added to default key accelerators
  • New Editor: Implemented user-defined colors/styles/font (from Tools->Preferences, “Editor”).
  • New Editor: Implemented Help features (access to help pages Function reference, Using AFL Editor, Param info, etc)
  • New Editor: Chart tree is auto-refreshed when formula is saved under new name (Save As…)
發表於 14-4-12 22:33 來自手機 | 顯示全部樓層
本帖最後由 kilroy 於 14-4-12 23:37 編輯
趁著週末來更新一下,感謝分享唷~
發表於 14-4-13 00:27 | 顯示全部樓層
我覺得這樣的 editor 更好唷~~
給個讚
GMT+8, 26-11-5 08:09
