查看: 2460|回復: 6
AmiBroker 5.77.0 BETA released
發表於 14-4-19 19:57 | 顯示全部樓層 |閱讀模式
April 18, 2014
A new beta version (5.77.0) of AmiBroker has just been released.
32-bit version:
http://www.amibroker.com/members/bin/ab5770beta.exe
(2 300 720 bytes)
64-bit version:
http://www.amibroker.com/members/bin/AmiBroker5770x64.exe
(9 515 576 bytes)
CHANGES FOR VERSION 5.77.0 (as compared to 5.76.0)
    New Editor: ‘Use separate frame’ mode implemented (Tools->Preferences, “Editor” to turn this off and open as tab in main frame)
    New Editor: Toolbar customization functionality added
    UI: Window->Toggle Frame menu/shortcut added to quickly switch between main and separate editor frame
    UI: Window menu reordered (Tile/Cascade items moved up)
    New Editor: in 5.76 pressing Help button on dialogs when new editor was open, directed help file to ‘formula editor’ page instead of given dialog help file. Fixed.
    New Editor: On dark backgrounds the selection is darker than it was before
    New Editor: typing non-US characters is now working
    New Editor: Copy As HTML implemented
    New Editor: added ability to turn off line number margin, selection margin, fold margin (from View menu)
    New Editor: added View->Fold All / Unfold All commands
    New Editor: when relative paths were used sometimes auto-reload and auto-save before analysis did not work. Fixed.
    New Editor: Caret Ln/Col position is displayed in the status bar
    New Editor: Closing top error message bar clears ALL in-line error messages
    New Editor: added Edit->Clear Error message menu (Ctrl+E) – it clears an error(s) in currently selected line/range
    New Editor: The width of line number margin is automatically adjusted with regards to font size and line count and zoom level
    New Analysis: Progress bar is shown/hid quicker
最近的改版對編輯器著墨甚多
發表於 14-4-19 20:23 來自手機 | 顯示全部樓層
排版比以前好太多了
不過在功能鍵方面有點怪怪的
小弟有寫信問作者了說
發表於 14-4-21 10:50 | 顯示全部樓層
編輯器以前是蠻爛的,我都用notepad++
 樓主| 發表於 14-4-21 20:55 | 顯示全部樓層
lwhuang 發表於 14-4-21 10:50
哈哈!我有一陣子也是嫌它爛,還特地找PSPad的AFL高亮語法定義檔來裝在PSPad中用
發表於 14-4-22 03:42 | 顯示全部樓層
新的編輯器是非常不錯的,到目前為止。
發表於 14-4-30 17:03 | 顯示全部樓層
最新版5.78好像也出来了耶
 樓主| 發表於 14-4-30 19:19 | 顯示全部樓層
DumbMoney 發表於 14-4-30 17:03
最新版5.78好像也出来了耶
不是好像,是已經
GMT+8, 26-11-5 06:07
