查看: 2330|回復: 3
AmiBroker 5.78.0 BETA released
發表於 14-4-26 09:34 | 顯示全部樓層 |閱讀模式
April 25, 2014
A new beta version (5.78.0) of AmiBroker has just been released.
32-bit version:
http://www.amibroker.com/members/bin/ab5780beta.exe
(2 303 592 bytes)
64-bit version:
http://www.amibroker.com/members/bin/AmiBroker5780x64.exe
(9 519 824 bytes)
CHANGES FOR VERSION 5.78.0 (as compared to 5.77.0)
    Prefs: “Use new editor” is now always turned ON at the start of application.
    Low Level Gfx: performance improved for formulas making thousands of calls to Gfx functions (3x speed up for 200K calls)
    Charts: cached bitmap is now stretched when chart is resized while the formula is being run
    On saving broker.newcharts file a backup file is created prior to saving. Then on startup in case broker.newcharts is corrupted, a backup file is used instead
    New Editor: when auto-complete was in immediate mode typing xx.a resulted in xx.AddCustomMetric to be shown immediately. Fixed – now in ‘immediate’ mode single-selection choices are not auto-completed without user consent.
    New Editor: when user selected black background the colors on printout are inverted to save toner/ink. Also added File->Print/Print Setup menu item.
    New Editor: on application close editor window frame is closed first instead of last. This gives more ‘graceful’ exit.
    New Editor: on dark backgrounds unmatched brace is displayed in lighter blue color (instead of dark blue) for better visibility
    New Editor: Autocomplete listbox is now dismissed when user drags separate editor frame or MDI child frame
    New Editor: now it uses application theme instead of hard-coded “VS2010″ theme
    New Editor: auto complete does not try to pop up in file paths in #includes. Also improved auto-complete operation in the very last line.
    New Editor prints debug string when saving document in order to diagnose possible issues with FAT32/WinXP
    Sometimes crash occured on Window->Floating command when Interpretation window was open. Fixed.
    UI: Window->Toggle Frame restores window from icon state (if was minimized) now.
    UI: added View->Fold / Unfold, Margin menu items in the MDI editor menu
    UI: Charts file treeview gets refreshed when saving AFL to any folder, not only ‘Custom’
    UI: Customize keyboard page now displays an error message on attempt to create shortcuts with A-Z letters and 0-9 digits without Ctrl/Shift/Alt modifiers to prevent clash with the editor
    UI: AFL formulas are saved in separate MRU (most recently used) list (File->Recent Formulas) so they do not interfere with other document types using Recent File list
發表於 14-4-26 14:24 來自手機 | 顯示全部樓層
感謝大大分享最新的更新
速度之快,接近每個禮拜都有更新了XD
發表於 14-4-28 07:42 | 顯示全部樓層
又被S大搶了一步,握拳
Sirius + 2 哈哈!下回讓給你
 樓主| 發表於 14-5-11 11:02 | 顯示全部樓層
lwhuang 發表於 14-4-28 07:42
又被S大搶了一步,握拳
哈囉!該換你上場了!
GMT+8, 26-11-5 08:09
