查看: 2187|回復: 2
AmiBroker 5.79.0 BETA released
發表於 14-5-12 08:56 | 顯示全部樓層 |閱讀模式
Sirius大承讓
AmiBroker 5.79.0 BETA releasedStability: – Regular BETA, pretty stable, should work fine in most environments
A new beta version (5.79.0) of AmiBroker has just been released.
32-bit version:
http://www.amibroker.com/members/bin/ab5790beta.exe
(2 321 432 bytes)
64-bit version:
http://www.amibroker.com/members/bin/AmiBroker5790x64.exe
(9 531 928 bytes)
ATTENTION: This version is free only for users who registered after May 8, 2012. See Upgrade Policy and Pricing section below for more details.
CHANGES FOR VERSION 5.79.0 (as compared to 5.78.0)
  • New Editor: Inverting colors on printout did not work for many backgrounds. Now white color is always used for background, foreground colors are kept unchanged, except for white which is replaced with black
  • New Editor: Changing formula name marks it as “modified” so Save icon becomes enabled
  • New Editor: Edit->Clear error message menu item added in MDI mode
  • New Editor: Save icon is now grayed when formula is not modified
  • New Editor: when separate editor frame was minimized, choosing “Edit formula” did not restore frame back to normal (non-minimized) state. Fixed.
  • New Editor: Fold/Unfold did not always work correctly. Fixed. Also Fold All folds on 1st level only, so it requires less clicks to unfold one section.
  • New Editor: Copy as HTML automatically replaces white font with black. Also HTML is shorter (black text does not use  tag) and coloring is forced, so long texts are correctly copied with colors.
  • New Editor: relative paths caused problems with ReplaceFile API and FAT32, so relative paths are now converted to absolute prior to saving
  • New Analysis now rejects attempts to use non-exhaustive optimization (OptimizeSetEngine) when number of exhaustive optimization steps is less than 100 (Error 708)
  • DB: when broker.markets, broker.groups, broker.workspace files were missing then markets and groups from previously loaded DB leaked to newly created/loaded db. Fixed – now they are always initialized with defaults. Also default market 0/group 0/sector 0/industry 0 is now labelled “Undefined”
  • ASCII import: $MARKET and $GROUP commands allow to specify the name of market/group (after comma) to be updated during import
  • UI: added File->Save All menu item to separate editor frame
  • AFL: reverted change #2623 as it resulted in regression in custom portfolio backtest speeds
  • Charts: Reverted #2621 change from 5.78.0 cached bitmap is now stretched when chart is resized while the formula is being run
  • Persistent variables that were loaded from PresistVar.bin but not updated by the formula were removed on next start. Now they are kept.
Sirius + 2 按一個讚
 樓主| 發表於 14-5-14 06:16 | 顯示全部樓層
也許下個版就是5.80了
發表於 14-5-16 03:46 | 顯示全部樓層
这次的改了什么呀,有翻译下来看看吗
GMT+8, 26-11-5 06:07
