樓主: skyler
AB 32bit 與 64bit 回測結果不同
發表於 14-5-19 10:36 | 顯示全部樓層
提出一個想法
策略開發的時候 都把數值用整數運算就好了
*1000  *100000  這樣
那結果還會不一樣嗎?
 樓主| 發表於 14-5-19 10:46 | 顯示全部樓層
wldtw2008 發表於 14-5-19 10:30
個人幾個想法:
1.
32/64的差異是在記憶體定址(整數運算),在浮點數運算方面,早在16位元的年代浮點數的運 ...
同意大大的看法
如果是精度問題
我要能跑出 32bit與64bit二者相同結果
的機會應該不太可能
這個問題
可大可小
如果統一在一個環境下做回測與交易
應該可以乎視這個問題
發表於 14-5-19 13:13 | 顯示全部樓層
本帖最後由 IBM2012 於 14-5-19 13:18 編輯
如果你去問AB的客服,他一定會教你去看他們家網頁的這一篇,哈哈哈~
JULY 20, 2010
About floating point arithmetic
In general, to represent numbers with fractional parts, computers use a “floating point” binary representation. Floating point arithmetic is also used by AmiBroker for AFL calculations. For some more information about floating point representation in general see the following article, here we will only discuss some practical aspects.
Floating point calculations are performed in hardware by FPU (Floating Point Unit), which today is a part of your computer’s processor (CPU). The calculations are performed according to IEEE754 standard (see below) that all CPU manufacturers follow.
Internally in computers all numbers are represented in binary system.
This fact has some important consequences in practice. One of it is that some fractions that have finite representation in decimal system are not finite in binary.
For example, 0.1 is endless (infinite) fraction in binary system, as 1/3 or 2/3 fractions are in decimal system.
The mantissa of 0.1 fraction in binary system is cyclical:
1001 1001 1001 1001 1001 1001 1001 1001 1001 1001 1001 1001 1001 1001 1001 1001 1001 (1001)* …….
* represents endless cycle.
Since computers operate on limited word length, 32 bit binary representation of 0.1 is:
01111011 10011001100110011001100 (not rounded) (in decimal it is 0.09999999403953552)
or
01111011 10011001100110011001101 (rounded) (in decimal it is 0.10000000149011612)
Later is used by FPU (floating point processor) in your CPU because it has smaller relative error. If you add it nine times you will end up with 0.9000000134110449 which is of course higher than 0.9.
It will be easier for you to understand when explaining on decimal numbers. For example 2/3 represented in decimal is:
0.666666667
Now add THREE times this number (0.666666667 + 0.666666667 + 0.666666667) and what you will get?
2.000000001 and that is greater than 2.
Therefore, it is rule in programming, NEVER use fractions for loop counters. For that reason you should not use fractions in Optimize(), or if you need to use them use them in WISE way by adding HALF of “step” value to the “max” value.
step = 0.1;
x = Optimize(“x”, 0.5, 0.1, 0.9 + step/2, step);
Another thing to keep in mind is that 32-bit floating point number has only 7 significant digits (those digits that carry meaning contributing to its precision). So in 123.4567 all digits are significant and accurate, but in 123.456789, last two digits (’8′ and ’9′) are not significant and subject to floating point rounding – see links below).
See also:
About significant figures:
IEEE754 conversion calculators:
IEEE754 standard description:
Essay about comparing floatin point numbers:
Microsoft Knowledge Base: “Precision and Accuracy in Floating-Point Calculations”
Using 32-bit floating point (as opposed to 64-bit double precision) has two main advantages:
a) consumes HALF of memory required for doubles (this *is* important, more important that you think, because if you have for example an array of 500000 elements, in floats it is 2MB and it fits into CPU cache, while in doubles it would be 4MB and may not fit into CPU cache).
b) 32-bit floating point numbers can be computed much faster. It simply takes less processor cycles to compute 32-bit float than 64-bit float. 64-bit version of AmiBroker is going even further and is using SSE2 instructions. This means that vectors of 4 single-precision numbers are processed in parallel using single SSE2 instruction on SINGLE processor. This gives more speed on single core than achievable using multiple cores.
Note also AmiBroker does use double precision (64bit) where it is necessary (for certain internal calculations)
參與人數 2金錢 +7 收起 理由
skyler + 2 好文章,我推薦
kilroy + 5 感謝分享
GMT+8, 26-11-5 08:07
