查看: 2990|回復: 1
AmiBroker 5.80.0 RC 1 released
發表於 14-6-5 09:08 | 顯示全部樓層 |閱讀模式
June 4, 2014
Stability: Rank 4 – Release candidate, pretty stable, should work fine in most environments
This is a Release Candidate version. Make a backup first
A new RC version (5.80.0) of AmiBroker has just been released.
32-bit version:
http://www.amibroker.com/bin/AmiBroker5800.exe
(9 086 968 bytes)
64-bit version:
http://www.amibroker.com/bin/AmiBroker5800x64.exe
(9 719 312 bytes)
ATTENTION: This version is free only for users who registered after May 8, 2012. See Upgrade Policy and Pricing section below for more details.
CHANGES FOR VERSION 5.80.0 (as compared to 5.79.0)
  •     New Analysis: An error 709 is displayed when user specified so many Optimize() calls that search space is larger than 10^19 combinations (100 times more than the age of The Universe in seconds)
  •     New Analysis: progress bar update is forced so even if program is 100% busy the progress bar gets repainted
  •     New Analysis: “the analysis is in progress” text was not always cleared after analysis has completed. Fixed.
  •     New Editor: Param info is displayed even when there are spaces between identifier and opening brace
  •     New Editor: A full path to formula is displayed in the Status bar when mouse hovers over formula name edit
  •     New Editor: pressing ENTER just after identifier name resulted in auto-change case function ommitting first letter of the word. Fixed
  •     New Editor: added Window->Keep On Top menu (in separate frame mode)
  •     New Editor: Auto-complete pop up in immediate mode now does not appear when editing existing word in the middle, but it is available on demand (Ctrl+SPACE)
  •     AFL: increased maximum acceptable value for ThreadSleep function to 1000 ms, and added appropriate level2 warning
  •     AFL: Error 52 wording changed from ‘argument must be positive’ to ‘argument must be greater than zero’
  •     UI: when any non-modal dialog was displayed, activation of the app always brought up main frame in front possibly hiding New Editor. Fixed.
  •     UI: removed “use new editor” option from Preferences window. New editor is always used now.
  •     UI: Main frame is now disabled (modal) when file dialog is open from AFL editor
  •     Pre-processor errors occuring in run-time caused that chart pane stopped refreshing. Fixed.
  •     Charts: Bar chart close/open ticks are by default one pixel smaller
  •     Weekly compression for Sunday data was off by one day for dates pre-1970. Fixed.
  •     Weekly compression now offers user-selectable “first day of the week” in File->Database Settings->Intraday Settings
  •     Application manifest modified to include compatibility section for Win 8.x
  •     Threads use current dir stored at application startup and resolve relative paths in AB, not to rely on Windows, so relative paths are resolved even if Windows changes dir
參與人數 4金錢 +11 收起 理由
enochyu + 2 感謝分享
skyler + 2 感謝分享
lwhuang + 2 感謝分享
kilroy + 5 感謝分享
發表於 14-6-5 20:48 | 顯示全部樓層
感謝分享^^
新手來學習的
GMT+8, 26-11-5 06:07
