查看: 3363|回復: 3
[工具] A new official release (5.80.2) of AmiBroker has just been published
發表於 14-6-26 06:29 | 顯示全部樓層 |閱讀模式
JUNE 25, 2014AmiBroker 5.80.2 official release
Stability: – Official Release, stable
This is a Official Release version.
A new official release (5.80.2) of AmiBroker has just been published.
32-bit version:
http://www.amibroker.com/bin/AmiBroker5802.exe
(9 088 824 bytes)
64-bit version:
http://www.amibroker.com/bin/AmiBroker5802x64.exe
(9 723 288 bytes)
ATTENTION: This version is free only for users who registered after May 8, 2012. See Upgrade Policy and Pricing section below for more details.
CHANGES FOR VERSION 5.80.2 (as compared to 5.80.0)
  • UI: Status bar prompt for recent databases and recent files was incorrect. Fixed.
  • When a formula that uses Category* functions is run inside commentary window, the symbol list is auto-refreshed now.
  • When commentary window was open on completely empty database a crash could occur. Fixed.
  • New Analysis: Progress bar is not hidden until custom portfolio backtest phase is completed
  • AFL: when artithmetic operator was applied to variable that was uninitialized or having invalid type a crash could occur. Fixed.
  • DB: If external data source set incorrect group or market or industry ID (lower than 0 or higher than 255) a crash could occur when updating symbol list. Fixed, incorrect data are switched back to zero and warning message is displayed.
  • New Editor: when user changes the formula name and presses “Save” the editor now displays a confirmation dialog if file already exists
  • Charting: X-axis grid calculation speeded up 3x (for large number of bars)
    When chart pane had NULL formula path attempt to edit formula or drag-drop it could cause crash. Fixed.
  • New Editor: crash could occur when formula was Saved as…” for the first time outside “Formulas” folder and its subfolders. Fixed.
  • AFL: Error 56 “Variable has an invalid type” added when variable has uninitialized type or type set to some strange value (plugins may cause this due to programmer error)
  • AFL: in multithreaded charts unhandled exceptions where not caught inside indicator even though preferences setting was to catch them. Fixed.
  • AFL: when formula is executed in “Indicator” mode the execution stops at very first error and this error is displayed as most relevant in the chart pane instead of last error which is usually not relevant (often side effect of previous errors)
參與人數 4金錢 +11 收起 理由
lwhuang + 2 感謝分享
skyler + 2 感謝分享
陳小花 + 2 真巧.....我是2012,May 9
kilroy + 5 感謝分享
發表於 14-6-26 22:41 | 顯示全部樓層
本帖最後由 skyler 於 14-6-26 22:49 編輯
剛測試有點問題
但已解決
感謝大大的分享~
發表於 14-6-27 07:54 | 顯示全部樓層
skyler大是遇到什麼問題?
我是watchlist有問題,把舊的watchlist都砍了就好了
發表於 14-6-27 08:37 | 顯示全部樓層
skyler 發表於 14-6-26 22:41
剛測試有點問題
但已解決
感謝大大的分享~
我是發現我做 scan 時只要在設定勾選了 wait for  backfill
就會停住不動
但沒勾又好了
我後來發現原來是跟eSignal的連接沒有連好
重開就解決了
GMT+8, 26-11-5 05:11
