查看: 2634|回復: 1
[工具] AmiBroker 5.84.0 BETA released
發表於 14-10-1 09:26 | 顯示全部樓層 |閱讀模式
September 27, 2014AmiBroker 5.84.0 BETA releasedStability: – Regular BETA, pretty stable, should work fine in most environments
A new beta version (5.84.0) of AmiBroker has just been released.
32-bit version:
http://www.amibroker.com/members/bin/ab5840beta.exe
(2 324 288 bytes)
64-bit version:
http://www.amibroker.com/members/bin/AmiBroker5840x64.exe
(9 729 248 bytes)
Note that this version can only be installed onto previous full installation of version 5.80 or higher from http://www.amibroker.com/download.html
CHANGES FOR VERSION 5.84.0 (as compared to 5.83.0)
  • AFL Editor: Idle-time Info tips were positioned incorrectly in 5.83. Fixed.
  • AFL Editor: Text of inserted snippet is selected so one can easily see what was inserted and delete it if was a mistake.
  • AFL: added Error 57. Invalid quotation mark (when user uses curly quotation marks instead of straight quotation marks ” to type a string literal)
  • OLE: Document object has new property Interval (integer, read/write) – selected Interval in seconds (tick/range/volume intervals are represented by negative values)
  • Report Charts: now it is possible to output HTML instead of graphics in report chart formulas using AFL: EnableTextOutput( 3 ) – HTML output to backtest report
  • Report Charts: rewritten 3. Profit Table.afl using HTML embedding features auto-scalable layout (so it enlarges when numbers are bigger), bold summary columns, negative values in red, boundary date changed to last day of year/month
  • UI: added Code Snippets window – allows inserting/deleting/saving selected parts of the formula as snippets. Also implemented is convenient drag-drop of snippet to the formula edit window
  • UI: Further display improvements of Parameter window for high-DPI displays (ParamList bullet point is bigger and positioned better, Slider is resized when resizing param window, etc, etc)
  • UI: On non-standard DPI displays Parameter window could show some visual artifacts when scrolling. Fixed.
參與人數 2金錢 +7 收起 理由
skyler + 2 感謝分享
kilroy + 5 感謝分享
發表於 14-10-1 23:20 | 顯示全部樓層
每天回那麼多技術支援的信件...........還能這麼更新軟體.........真不知道是怎麼做到的..
GMT+8, 26-11-5 06:07
