查看: 3329|回復: 1
[工具] AmiBroker 5.86.0 BETA released
發表於 14-10-11 18:55 | 顯示全部樓層 |閱讀模式
OCTOBER 11, 2014AmiBroker 5.86.0 BETA released
Stability: – Regular BETA, pretty stable, should work fine in most environments
A new beta version (5.86.0) of AmiBroker has just been released.
32-bit version:
http://www.amibroker.com/members/bin/ab5860beta.exe
(2 385 312 bytes)
If you can not log in into members’ area please get your new password by filling the form at:http://www.amibroker.com/login.html
Note that this version can only be installed onto previous full installation of version 5.80 or higher from http://www.amibroker.com/download.html
CHANGES FOR VERSION 5.86.0 (as compared to 5.85.0)
  • AFL Editor: repeat replace + wrap around restarts only once and if no further matches/replaces are found it displays “no more matching texts” instead of restarting again.
  • AFL Editor: when user closed Find&Replace dialog and then pressed F3 (find next) a couple of times to pass thru the end of document a crash could occur. Fixed.
  • Analysis: HTML report generator – settings page used tags to close some tags which is formally incorrect, even if it works. Fixed.
  • Charts: Extreme descenders in text could be truncated (by one pixel) in multiple line Title strings. Fixed.
  • HTMLView – Backtest report viewer – added Edit/Copy, Edit/Select All and Edit/Copy TABLE. The last command transforms HTML tables into CSV format and copies it into clipboard so tables can be pasted easily to Excel. Also it divides Entry/Exit columns into separate Entry/exit date/price columns
  • Parameter window: mouse wheel scroll is now supported
  • Realtime Quote window: added Bid/Ask trend – a graphical indicator showing the direction of 10 most recent changes in bid/ask prices
  • Realtime Quote window: Sorting by Full name column did no work. Fixed
  • Report Explorer: Column layout (order and sizes) is now saved and restored between runs
  • Report Explorer: Loading and refresh performance significantly improved (5x) using owner draw/ virtual mode
  • Report Explorer: Multi-column sorting implemented
  • Report Explorer: Numeric columns are now right aligned for better readability
  • Report Explorer: visuals significantly improved (list uses modern style, grid lines, immediate column resizing, double buffering for no flicker, thousand separators, negative values are displayed in dark red, HighDPI aware, changed toolbar)
  • Snippet properties window now includes formula field for quick reference (no highlighting here – it is by design)
參與人數 2金錢 +7 收起 理由
lwhuang + 2 感謝分享
kilroy + 5 感謝分享
 樓主| 發表於 14-10-14 18:56 | 顯示全部樓層
作者大大真的是辛苦了..........要回應技術支援....又要開發新版....最近都不想煩他
各位大大有空可以讀一下:
How to get support most efficiently
= http://www.amibroker.com/kb/2014/10/09/efficient-support/
GMT+8, 26-11-5 08:08
