查看: 2838|回復: 0
AmiBroker 5.90.0 Release Candidate 1
發表於 14-11-13 12:25 | 顯示全部樓層 |閱讀模式
NOVEMBER 12, 2014AmiBroker 5.90.0 Release Candidate 1
Stability: – Release Candidate, pretty stable, should work fine in most environments
This is a Release Candidate version. Make a backup first
A new Release Candidate version (5.90.0) of AmiBroker has just been published.
It comes with full setup, updated documentation, etc.
CHANGES FOR VERSION 5.90.0 (as compared to 5.89.0)
  • AFL Editor: keytrigger expansion wasn’t properly undone (via Edit->undo). Fixed.
  • AFL Editor: when last document was closed usign tab “X” mark the message prompt that asked to save changes could pop up on wrong monitor in multiple monitor setups and not disable AFL editor frame making it possible to press “X” again and cause re-entrancy problem/crash. Fixed.
  • Charts: rarely when chart sheets were switched an attempt to free already freed memory could occur. Fixed.
  • DB: fixed crash when switching databases while outstanding call for Foreign from other thread was attempting to bring up other symbol data.
  • IB plugin allowed to trigger backfill even if it was not connected causing potential freeze/crash. Fixed.
  • New Analysis: added error message when user has incorrect setting for PointValue. PointValue MUST be greater than zero.
  • OLE: attempt to set negative or zero PointValue results in exception
  • Parameter window: when screen size is not enough to fit color popup beneath color item, the popup is now displayed above the item
參與人數 2金錢 +7 收起 理由
Sirius + 2 按一個讚
kilroy + 5 感謝分享
GMT+8, 26-11-5 06:07
