查看: 47374|回復: 7
AmiBroker 6.03.0 BETA released
發表於 15-11-7 10:28 | 顯示全部樓層 |閱讀模式
November 6, 2015
A new beta version (6.03.0) of AmiBroker has just been released.
32-bit version:
http://www.amibroker.com/members/bin/ab6030beta.exe
(2 354 368 bytes)
64-bit version:
http://www.amibroker.com/members/bin/AmiBroker6030x64.exe
(10 101 672 bytes)
Note that this version can only be installed onto previous full installation of version 6.00 or higher from http://www.amibroker.com/download.html
HOW TO USE NEW FEATURES
This version contains a brand new AFL visual debugger. Detailed description of how to use the debugger is provided here: http://www.amibroker.com/guide/h_debugger.html
CHANGES FOR VERSION 6.03.0 (as compared to 6.02.0)
  • AFL Editor: Implemented fully integrated Visual AFL Debugger. Note: this is work in progress and more things are to come
  •     Debugger: Implemented breakpoints (including those set before compilation as well as adding/removing breakpoints during debugging)
  •     Debugger: Implemented single-stepping Step Into, Step Over
  •     Debugger: Implemented variable value inspection tooltips (hover mouse over variable to see its value)
  •     Debugger: Implemented Watch window with variable value display automatically updating when debugger single-steps or reaches breakpoint
  •     AFL: Sum(array,N) outputs NULL values for indices starting from 0 upto index N-1 instead of N    Renaming of PersistVars.temp to PersistVars.bin failed on some versions of OS. Fixed.
  • RT Quote window: drag-drop list view shows small arrow marker for the drop point now.
  • RT Quote window: when moving items using drag-drop, moved items image was flickering. Fixed
  • UI: Chart zoom via Ctrl+mouse wheel now works so it attempts to current mouse position as a “center” point of zoom when possible. (Previously it always worked so right border was the ‘center’).
  • When intraday data were used timestamp of 00:00:00 was not displayed in data tooltip (empty field was shown). Fixed.
參與人數 2金錢 +7 收起 理由
kilroy + 5 感謝分享
lwhuang + 2 終於有debugger了
發表於 15-11-7 21:49 | 顯示全部樓層
Also see:
THINGS NOT IMPLEMENTED YET BUT PLANNED FOR FEW NEXT BETAS:
    Debugger: automatically saving/restoring breakpoints and watches between sessions in xml file
    Debugger: exploration-like full array display in separate tab in Watch window
    Debugger: output window (for printf output)
    Debugger: display all elements of matrices in value inspection tooltips / watch window
    Debugger: (maybe) simple expression evaluator for watch window
    Debugger: MDI mode
And
In the future versions you will be able to mark and drag variable from editor onto Watch window.
Hello,
Thank you very much for your e-mail.
Yes, currently debugger uses fixed 200 bars, but there will be a setting in the future
that would allow user to decide how many bars use for debugging.
So if condition is not met, the code inside conditional part would not be reached
and breakpoint would not be hit.
The other thing that I did not mention in DevLog is that debugger and watch window
currently are working in the "separate frame" editor mode only.
Best regards,
Tomasz Janeczko
amibroker.com
Release notes
http://www.amibroker.com/devlog/category/releases/
How to:
發表於 15-11-8 08:30 | 顯示全部樓層
有想要付錢更新了
發表於 15-11-8 22:18 | 顯示全部樓層
為啥呢
新版看中哪個功能
發表於 15-11-9 11:40 | 顯示全部樓層
andy03 發表於 15-11-8 22:18
為啥呢
新版看中哪個功能
debugger呀
不然都跑一跑,不知道死在那裡
發表於 15-11-10 02:06 | 顯示全部樓層
听說MC很準砲的
不知AmiBroker回測跟實際下單差多少
發表於 15-11-10 04:42 | 顯示全部樓層
听說MC很準砲的
very accurate?
*LMAO*
發表於 17-8-21 11:01 | 顯示全部樓層
感謝版主分享!
GMT+8, 26-11-5 05:04
