查看: 2930|回復: 0
AmiBroker 6.05.0 BETA released
發表於 15-11-22 10:14 | 顯示全部樓層 |閱讀模式
November 21, 2015
A new beta version (6.05.0) of AmiBroker has just been released.
32-bit version:
http://www.amibroker.com/members/bin/ab6050beta.exe
(2 365 088 bytes)
64-bit version:
http://www.amibroker.com/members/bin/AmiBroker6050x64.exe
(10 111 936 bytes)
Note that this version can only be installed onto previous full installation of version 6.00 or higher from http://www.amibroker.com/download.html
HOW TO USE NEW FEATURES
This version contains a brand new AFL visual debugger. Detailed description of how to use the debugger is provided here: http://www.amibroker.com/guide/h_debugger.html
CHANGES FOR VERSION 6.05.0 (as compared to 6.04.0)
  • AFL Editor Find in Files implemented – on the output list you can double click on line to open the file in the editor
  •     AFL Editor/Debugger: Code Check and Profile stopped working when it was run after debugging session. Fixed.
  •     AFL: Null is accepted by MxFromString now
  •     AFL: performance of printf() for large volume output (>60000 characters) improved ~60 times.
  •     Charts: reduced tearing when resizing the chart window
  •     Debugger now can use either base time interval or current chart interval (Tools->Preferences, Debugger tab, “Bar interval” setting)
  •     Debugger: implemented Output window (for printf() output during debugging)
  •     Removed old-style legacy AFL editor from the code, removed “use new editor” checkbox from the preferences. A new editor is used always now.
  •     UI: Unfold triangles in tree views and checkboxes in Layers list were hard to click on HighDPI screens because icons were too small. Fixed.
  •     Watch window: now expressions with 2D subscripts to access elements of matrix matrix[ x ][ y ] are supported
參與人數 2金錢 +7 收起 理由
lwhuang + 2 感謝分享
kilroy + 5 感謝分享
GMT+8, 26-11-5 00:16
