查看: 3487|回復: 0
AmiBroker 6.07.0 BETA released
發表於 15-12-5 07:59 | 顯示全部樓層 |閱讀模式
December 4, 2015
A new beta version (6.07.0) of AmiBroker has just been released.
32-bit version:
http://www.amibroker.com/members/bin/ab6070beta.exe
(2 370 672 bytes)
64-bit version:
http://www.amibroker.com/members/bin/AmiBroker6070x64.exe
(10 117 192 bytes)
Note that this version can only be installed onto previous full installation of version 6.00 or higher from http://www.amibroker.com/download.html
HOW TO USE NEW FEATURES
This version contains a brand new AFL visual debugger. Detailed description of how to use the debugger is provided here: http://www.amibroker.com/guide/h_debugger.html
CHANGES FOR VERSION 6.07.0 (as compared to 6.06.0)
  • AFL: compression for array Static variables implemented to save memory and file size: StaticVarSet has additional parameter that controls compression
  •     AFL: printf/StrFormat check for %s, %c, %d, %x, %i, %u, %x, %p sequences that are not supported now and prints Error 62 when they are found.
  •     AFL: printf/StrFormat now implement a check for correct formatting string as sometimes users passed strings with % that is special marker for formatting string instead of %% to print actual percent sign
  •     AFL: Some variable period functions such as Ref/Sum/MA incorrectly accepted matrix as a ‘period’. Fixed (proper error message is displayed now).
  •     AFL: StaticVarGet/StaticVarSet functions now support matrices including persistency (so matrices can be written to disk and loaded back between AmiBroker runs)
  •     AFL: VarSet/VarGet officially accept matrices (allow dynamic variables of matrix type). (FWIW they were accepted in previous versions but implementation was incomplete.)
  •     Charting: Candlestick wicks thickness is now user definable as % of candle width with a max. pixel width (Tools->Preferences, “Bars and Candles” tab). Also by default wick thickness is now 25%/5px max instead of constant 1 pixel.
  •     Charting: Cycles tool in weekly chart produced incorrect lines when it went past 2038. Fixed.
  •     Charting: Horizontal line tool level is now displayed with number of decimals as defined in Preferences (Misc tab, “decimal places in chart titles/tools”). Note that this setting is used when you draw a new line or modify old.
  •     Debugger: Added F5 key as keyboard shortcut for “Debug / Go”
參與人數 2金錢 +7 收起 理由
lwhuang + 2 感謝分享
kilroy + 5 感謝分享
GMT+8, 26-11-5 02:10
