查看: 3907|回復: 0
[工具] AmiBroker 6.13.0 BETA is released now
發表於 16-4-25 06:47 | 顯示全部樓層 |閱讀模式
最近更新的很頻繁
http://www.amibroker.com/devlog/2016/04/24/amibroker-6-13-0-beta-released/
April 24, 2016AmiBroker 6.13.0 BETA releasedStability: – Regular BETA, pretty stable, should work fine in most environments
A new beta version (6.13.0) of AmiBroker has just been released.
32-bit version:
http://www.amibroker.com/members/bin/ab6130beta.exe
(2 219 112 bytes)
64-bit version:
http://www.amibroker.com/members/bin/AmiBroker6130x64.exe
(10 433 160 bytes)
Note that this version can only be installed onto previous full installation of version 6.10 or higher from http://www.amibroker.com/download.html
CHANGES FOR VERSION 6.13.0 (as compared to 6.12.0)
  • AFL Editor: calling SetForeign thousands of times followed by RestorePriceArrays() could cause exception during code verify when number of symbols exceeded cache size. Fixed.
  • AFL Editor: changes made in 6.11 to the way how automatic names for new formulas are assigned have been removed and replaced by new method that is faster and more reliable.
  • AFL Editor: if clipboard is locked by another application the editor would retry opening clipboard upto 8 times before giving up
  • AFL Editor: when formula was open cursor was located at the end. Now it is located at the top.
  • AFL:  GfxSetCoordsMode( mode ) accepts now four different modes
  • AFL: MA function made upto 2 times faster, StDev function made 20% faster, Correlation made 40% faster
  • AFL: NormDist( x, mean = 0, sigma = 1, cumulative = True ) function. Implements hi-precision algorithm.
  • AFL: PriceVolDistribution( priceH, priceL, vol, bins, absolute = False, startbar = 0, endbar = -1 )
  • AFL: 64-bit version AFL Correlation() produced slightly different values (+/-0.00001 typ) than 32-bit version due to compiler differences. Now 64-bit version produces same values as produced by all 32-bit versions.
  • Charting: new feature – Snap to Tick grid. Snap drawing tool end points to TickSize-spaced grid (if TickSize > 0 for given symbol)
  • Plugin loading routine displays a message box when plugins with incorrect bitness are found
  • Plugin loading routine writes detailed error message to the broker.log in case of problem of DLL loading (must enable plugin log to use this feature)
  • When drawn study is being modified, Y distance shown in the status bar accounts for activated snap-to-price and/or snap-to-tick mode now.
lwhuang + 2 感謝分享
Sirius + 2 感謝分享
GMT+8, 26-11-5 04:01
