查看: 3084|回復: 0
AmiBroker 6.14.0 BETA released
發表於 16-6-19 11:11 | 顯示全部樓層 |閱讀模式
June 18, 2016
[url=www.amibroker.com/devlog/2016/06/18/amibroker-6-14-0-beta-released/chttp://www.amibroker.com/devlog/ ... 14-0-beta-released/]AmiBroker 6.14.0 BETA released[/url]
A new beta version (6.14.0) of AmiBroker has just been released.
32-bit version:
http://www.amibroker.com/members/bin/ab6140beta.exe
(2 222 440 bytes)
64-bitversion:
http://www.amibroker.com/members/bin/AmiBroker6140x64.exe
(10 439 928 bytes)
Note that this version can only be installed onto previous full installation of version 6.10 or higher from http://www.amibroker.com/download.html
CHANGES FOR VERSION 6.14.0 (as compared to 6.13.0)
  • AFL: ParamDate() added support for format=2 to return datetime instead of datenum/string
  • AFL: PercentRank function now accepts variable period (range)
  • AFL: PriceVolDistribution crashed if startbar argument was negative. Fixed by implementing protection against negative bar indexes.
  • AFL: PriceVolDistribution sometimes produced some random values in 6.13. Fixed.
  • ASCII importer now supports microsecond resolution timestamps (HH:MM:SS.mmmuuu) where mmm – milliseconds 000..999, uuu – microseconds 000..999
  • New Analysis: new feature a PAUSE button to temporarily pause/resume any running analysis. Note that already running threads are not interrupted, they are allowed to complete gracefully and then pause state is entered.
  • UI: A warning message is displayed when user attempts to close AmiBroker while Analysis is in progress
  • UI: QuoteEditor in some cases did not properly round fractional part of millisecond down to microsecond. Fixed
  • UI: QuoteEditor: Edit fields for OHLC prices, Volume, OpenInt and Aux now check for proper entry as you type and display red background if entered string is not proper numer. Also those edit fields don’t accept characters other than digits (0..9), decimal
  • UI: Toolbar icons are set to “Large icons” mode automatically on HighDPI screens
  • When broker.workspace file was corrupted or truncated, the file remained open which eventually prevented from writing it on close. Fixed.
lwhuang + 2 感謝分享
manhavecoco + 1 太強了
GMT+8, 26-11-5 05:09
