樓主: tinyding
2016-11-28 摩根台指期 1611 結算倒數!! ...
 樓主| 發表於 16-11-26 10:45 | 顯示全部樓層
tinyding 發表於 16-11-25 21:01
【多想翻盤片】募1.5億 美總統候選人申請2州重驗票  蘋果即時
川普1%險勝是真的? 美威州確定重驗票  蘋果即時
 樓主| 發表於 16-11-26 10:51 | 顯示全部樓層
 樓主| 發表於 16-11-26 14:09 | 顯示全部樓層
http://www.coco-in.net/forum.php?mod=redirect&goto=findpost&ptid=50047&pid=718711
太久沒有備份與還原系統了 ... 這次在過程中, 才發現 Sector Bytes 有 "512" 與 "4096" 之分別 ...
底下是 WD4002FYYZ 與 HTS721010A9E630 硬碟在 fdisk 程式底下所看到的狀態( 但由於 WD4002FYYZ 又透過 "Digifusion RHU05 硬碟座" 轉接, 是故參數有可能不是實際的? ) :
  1. Welcome to fdisk (util-linux 2.28.2).
  2. Changes will remain in memory only, until you decide to write them.
  3. Be careful before using the write command.
  4. Command (m for help): p
  5. Disk /dev/sdb: 3.7 TiB, 4000787030016 bytes, 7814037168 sectors
  6. Units: sectors of 1 * 512 = 512 bytes
  7. Sector size (logical/physical): 512 bytes / 512 bytes
  8. I/O size (minimum/optimal): 512 bytes / 512 bytes
  9. Disklabel type: gpt
  10. Disk identifier: 0E3E0F16-F238-4618-81A6-DC2DBE7E2191
  11. Device          Start        End    Sectors  Size Type
  12. /dev/sdb1          34     262177     262144  128M Microsoft reserved
  13. /dev/sdb2      264192 3907149823 3906885632  1.8T Microsoft basic data
  14. /dev/sdb3  3907149824 7814033407 3906883584  1.8T Microsoft basic data
  15. Command (m for help):
  16. Welcome to fdisk (util-linux 2.28.2).
  17. Changes will remain in memory only, until you decide to write them.
  18. Be careful before using the write command.
  19. Command (m for help): p
  20. Disk /dev/sda: 931.5 GiB, 1000204886016 bytes, 1953525168 sectors
  21. Units: sectors of 1 * 512 = 512 bytes
  22. Sector size (logical/physical): 512 bytes / 4096 bytes
  23. I/O size (minimum/optimal): 4096 bytes / 4096 bytes
  24. Disklabel type: dos
  25. Disk identifier: 0x1e721e72
  26. Device     Boot     Start        End    Sectors   Size Id Type
  27. /dev/sda1  *         2048     206847     204800   100M  7 HPFS/NTFS/exFAT
  28. /dev/sda2          206848  419637247  419430400   200G  7 HPFS/NTFS/exFAT
  29. /dev/sda3       419637248 1953525167 1533887920 731.4G  7 HPFS/NTFS/exFAT
  30. Command (m for help):
原先的作業系統在 WD1600BEVS-22RST0 硬碟 ( 容量約 160GB ) 上面, 經過 Clonezilla 的備份再還原到 HTS721010A9E630 硬碟 ( 容量約 1TB ) 上面 ...
在過程中, 也失敗好幾次 ( 資料拷貝過去了, 但辨識不出有 Windows OS 安裝在裡頭 ) ...
在原作業系統能在新硬碟上面成功開機後, 又碰到 "Windows Update" 異常以及事件記錄檔記錄著 "wuaueng.dll (936) SUS20ClientDataStore:無法讀取記錄檔 C:\Windows\SoftwareDistribution\DataStore\Logs\edb.log 標頭。錯誤 -546。" ... 就如同 https://support.microsoft.com/zh-tw/kb/982018 網頁裡頭所描述的情形 ... 所幸! 按照網頁裡頭所指示的步驟來做, 順利將問題給排除掉了 ... ^_^
底下是停止 "Windows Update" 以及重建 Log 相關檔案 ... :
  1. Microsoft Windows [版本 6.1.7600]
  2. Copyright (c) 2009 Microsoft Corporation.  All rights reserved.
  3. C:\Windows\system32>fsutil fsinfo ntfsinfo c:
  4. NTFS 磁碟區序號 :            0x98f2e228f2e209f8
  5. 版本 :                       3.1
  6. 磁區數目 :                   0x0000000018fffff8
  7. 叢集總數 :                   0x00000000031fffff
  8. 可用叢集 :                   0x000000000246f6be
  9. 保留總數 :                   0x00000000000007e0
  10. 每一磁區的位元組 :           512
  11. 每一叢集的位元組 :           4096
  12. 每一檔案記錄區段的位元組   : 1024
  13. 每一檔案記錄區段的叢集     : 0
  14. Mft 有效資料長度 :           0x000000000a1c0000
  15. Mft 開始 Lcn  :              0x00000000000c0000
  16. Mft2 開始 Lcn :              0x0000000000000002
  17. Mft 區域開始  :              0x00000000008420c0
  18. Mft 區域結束  :              0x0000000000844380
  19. RM 識別元:        BECBE463-8939-11E1-8CE4-F5B68B90E73D
  20. C:\Windows\system32>net stop "windows update"
  21. Windows Update 服務正在停止.
  22. Windows Update 服務已經成功停止。
  23. C:\Windows\system32>cd /d %windir%\SoftwareDistribution\DataStore\Logs
  24. C:\Windows\SoftwareDistribution\DataStore\Logs>esentutl /mh ..\DataStore.edb | f
  25. indstr /i /c:"State:"
  26.             State: Clean Shutdown
  27. C:\Windows\SoftwareDistribution\DataStore\Logs>mkdir c:\backuplogs
  28. C:\Windows\SoftwareDistribution\DataStore\Logs>dir
  29. 磁碟區 C 中的磁碟沒有標籤。
  30. 磁碟區序號:  F2E2-09F8
  31. C:\Windows\SoftwareDistribution\DataStore\Logs 的目錄
  32. 2016/11/24  下午 06:48    <DIR>          .
  33. 2016/11/24  下午 06:48    <DIR>          ..
  34. 2016/11/24  下午 06:52             8,192 edb.chk
  35. 2016/11/24  下午 06:52         1,310,720 edb.log
  36. 2016/11/21  上午 11:59         1,310,720 edb000A7.log
  37. 2012/04/18  下午 05:50         1,310,720 edbres00001.jrs
  38. 2012/04/18  下午 05:50         1,310,720 edbres00002.jrs
  39.                5 個檔案       5,251,072 位元組
  40.                2 個目錄  156,475,285,504 位元組可用
  41. C:\Windows\SoftwareDistribution\DataStore\Logs>move * c:\backuplogs
  42. C:\Windows\SoftwareDistribution\DataStore\Logs\edb.chk
  43. C:\Windows\SoftwareDistribution\DataStore\Logs\edb.log
  44. C:\Windows\SoftwareDistribution\DataStore\Logs\edb000A7.log
  45. C:\Windows\SoftwareDistribution\DataStore\Logs\edbres00001.jrs
  46. C:\Windows\SoftwareDistribution\DataStore\Logs\edbres00002.jrs
  47. 移動         5 個檔案。
  48. C:\Windows\SoftwareDistribution\DataStore\Logs>net start "windows update"
  49. Windows Update 服務正在啟動 .
  50. Windows Update 服務已經啟動成功。
  51. C:\Windows\SoftwareDistribution\DataStore\Logs>dir
  52. 磁碟區 C 中的磁碟沒有標籤。
  53. 磁碟區序號:  F2E2-09F8
  54. C:\Windows\SoftwareDistribution\DataStore\Logs 的目錄
  55. 2016/11/25  下午 06:50    <DIR>          .
  56. 2016/11/25  下午 06:50    <DIR>          ..
  57. 2016/11/25  下午 06:50             8,192 edb.chk
  58. 2016/11/25  下午 06:50         1,310,720 edb.log
  59. 2016/11/25  下午 06:50         1,310,720 edbres00001.jrs
  60. 2016/11/25  下午 06:50         1,310,720 edbres00002.jrs
  61. 2016/11/25  下午 06:50                 0 edbtmp.log
  62. 2016/11/25  下午 06:50           524,288 tmp.edb
  63.                6 個檔案       4,464,640 位元組
  64.                2 個目錄  156,465,192,960 位元組可用
參考 :
已提供可改善 Windows 7 和 Windows Server 2008 R2 與進階格式磁碟之相容性的更新  Microsoft :
Chapter 1 : 先進格式化硬碟  阿旺的 Linux 開竅手冊 :
http://wanggen.myweb.hinet.net/ech1/ech1.html
taitanwu + 2 按一個讚,感覺好複雜
 樓主| 發表於 16-11-26 15:03 | 顯示全部樓層
 樓主| 發表於 16-11-26 15:15 | 顯示全部樓層
tinyding 發表於 16-11-26 15:03
古巴革命強人 斐代爾‧卡斯楚過世  天下雜誌
古巴強人卡斯楚驚傳過世 享壽90歲  蘋果即時
 樓主| 發表於 16-11-26 15:24 | 顯示全部樓層
 樓主| 發表於 16-11-26 15:29 | 顯示全部樓層
 樓主| 發表於 16-11-26 15:57 | 顯示全部樓層
發表於 16-11-26 21:58 | 顯示全部樓層
dom551 + 2 按一個讚
發表於 16-11-27 11:21 | 顯示全部樓層
連一個 復興航空 您都不聞不問 還妄想讓台灣變猛虎 其實您的意思台灣是隻病狗
 樓主| 發表於 16-11-27 11:48 | 顯示全部樓層
 樓主| 發表於 16-11-27 11:58 | 顯示全部樓層
發表於 16-11-27 12:02 | 顯示全部樓層
卡屍處是暴君 川普喔YA 讚喔
發表於 16-11-27 12:03 | 顯示全部樓層
川普 當您登基 記得發射幾顆核彈試試
 樓主| 發表於 16-11-27 12:06 | 顯示全部樓層
GMT+8, 26-11-24 14:41
