查看: 55602|回復: 0
QQE
發表於 16-11-26 15:30 | 顯示全部樓層 |閱讀模式
#property copyright "Copyright ?2008 Tim Hyder"
#property link      "mailto:hiachiever@gmail.com"
#define vers    "09.Feb.2008"
#define major   1
#define minor   0
#property indicator_separate_window
#property indicator_buffers 2
#property indicator_color1 DodgerBlue
#property indicator_style1 STYLE_SOLID
#property indicator_width1 2
#property indicator_color2 Yellow
#property indicator_style2 STYLE_DOT
#property indicator_level1 50
#property indicator_levelcolor Aqua
#property indicator_levelstyle STYLE_DOT
extern string NOTESETTINGS=" --- INDICATOR SETTINGS ---";
extern int SF=5;
extern string NOTEALERTS=" --- Alerts ---";
extern int AlertLevel=50;
extern bool MsgAlerts=true;
extern bool SoundAlerts=true;
extern string SoundAlertFile="alert.wav";
extern bool eMailAlerts=false;
int RSI_Period=14;
int Wilders_Period;
int StartBar, LastAlertBar;
datetime LastAlertTime;
double TrLevelSlow[];
double AtrRsi[];
double MaAtrRsi[];
double Rsi[];
double RsiMa[];
int init()
   Wilders_Period=RSI_Period * 2 - 1;
   if (Wilders_Period < SF)
      StartBar=SF;
   else
      StartBar=Wilders_Period;
   IndicatorBuffers(6);
   SetIndexBuffer(0, RsiMa);
   SetIndexStyle(0, DRAW_LINE, STYLE_SOLID, 2);
   SetIndexLabel(0, "Value 1");
   SetIndexDrawBegin(0, StartBar);
   SetIndexStyle(1, DRAW_LINE, STYLE_DOT);
   SetIndexBuffer(1, TrLevelSlow);
   SetIndexLabel(1, "Value 2");
   SetIndexDrawBegin(1, StartBar);
   SetIndexBuffer(2, AtrRsi);
   SetIndexBuffer(3, MaAtrRsi);
   SetIndexBuffer(4, Rsi);
   IndicatorShortName(StringConcatenate("QQE(", SF, ")"));
   LastAlertBar=Bars-1;
   return(0);
int start()
   int counted, i;
   double rsi0, rsi1, dar, tr, dv;
   if(Bars<=StartBar)
      return(0);
   counted=IndicatorCounted();
   if(counted < 1)
      for(i=Bars - StartBar; i < Bars; i++)
         TrLevelSlow[i]=0.0;
         AtrRsi[i]=0.0;
         MaAtrRsi[i]=0.0;
         Rsi[i]=0.0;
         RsiMa[i]=0.0;
   counted=Bars - counted - 1;
   for(i=counted; i>=0; i--)
      Rsi[i]=iRSI(NULL, 0, RSI_Period, PRICE_CLOSE, i);
      RsiMa[i]=iMAOnArray(Rsi, 0, SF, 0, MODE_EMA, i);
      AtrRsi[i]=MathAbs(RsiMa[i + 1] - RsiMa[i]);
      MaAtrRsi[i]=iMAOnArray(AtrRsi, 0, Wilders_Period, 0, MODE_EMA, i);
   i=counted + 1;
   tr=TrLevelSlow[i];
   rsi1=iMAOnArray(Rsi, 0, SF, 0, MODE_EMA, i);
   while(i > 0)
      i--;
      rsi0=iMAOnArray(Rsi, 0, SF, 0, MODE_EMA, i);
      dar=iMAOnArray(MaAtrRsi, 0, Wilders_Period, 0, MODE_EMA, i) * 4.236;
      dv=tr;
      if (rsi0 < tr)
         tr=rsi0 + dar;
         if (rsi1 < dv)
            if (tr > dv)
               tr=dv;
      else if (rsi0 > tr)
            tr=rsi0 - dar;
            if (rsi1 > dv)
               if (tr < dv)
                  tr=dv;
      TrLevelSlow[i]=tr;
      rsi1=rsi0;
   if ((RsiMa[i+1]<AlertLevel && RsiMa[i]>AlertLevel) ||(RsiMa[i+1]>AlertLevel && RsiMa[i]<AlertLevel) )
      string base=Symbol()+ ", TF: " + TF2Str(Period());
      string Subj=base + ", " + AlertLevel + " level Cross Up";
      if (RsiMa[i+1]>AlertLevel && RsiMa[i]<AlertLevel) Subj=base + " " +  AlertLevel + " level Cross Down";
      string Msg=Subj + " @ " + TimeToStr(TimeLocal(),TIME_SECONDS);
      if (Bars>LastAlertBar)
         LastAlertBar=Bars;
         DoAlerts(Msg,Subj);
   return(0);
void DoAlerts(string msgText,string eMailSub)
   if (MsgAlerts) Alert(msgText);
   if (SoundAlerts)  PlaySound(SoundAlertFile);
   if (eMailAlerts) SendMail(eMailSub, msgText);
string TF2Str(int period)
   switch(period)
      case PERIOD_M1: return("M1");
      case PERIOD_M5: return("M5");
      case PERIOD_M15: return("M15");
      case PERIOD_M30: return("M30");
      case PERIOD_H1: return("H1");
      case PERIOD_H4: return("H4");
      case PERIOD_D1: return("D1");
      case PERIOD_W1: return("W1");
      case PERIOD_MN1: return("MN");
   return(Period());
GMT+8, 26-11-12 19:21
