查看: 4917|回復: 0
AmiBroker 6.20.1 Release Candidate
發表於 17-2-18 16:00 | 顯示全部樓層 |閱讀模式
February 17, 2017
Stability: Rank 5 – stable, should work fine in most environments
A new Release Candidate version (6.20.1) of AmiBroker, complete with full setup, data files and updated documentation has just been released. This version is going to become official after one week if no important issues surface.
32-bit version:
http://www.amibroker.com/members/bin/AmiBroker6201.exe
(9 905 152 bytes)
64-bit version:
http://www.amibroker.com/members/bin/AmiBroker6201x64.exe
(10 591 808 bytes)
UPGRADE POLICY
This version is a free upgrade only for users who registered AmiBroker after February 17, 2015. Users who registered earlier, would need to purchase license upgrade. To find out the version you currently have use Account Information page at http://www.amibroker.com/members/info.php
NOTE: This version works both as fresh first-time install and as in-place upgrade. Previous installation (if any) is detected and setup switches into ‘upgrade’ mode. Don’t worry, your charts, formulas, etc won’t be affected by the upgrade.
CHANGES FOR VERSION 6.20.1 (as compared to 6.20.0)
  • Batch: DataImportASCII command allows to automate imports via batch. The parameter is file name to be imported. The importer uses file extension to determine format file used, so if you are importing File.aqh then aqh.format definition file will be used
  • Default for time compression timestamping changed to recommended value, i.e. ‘start time of interval’
  • Plugin API: added GetExtraDataEx to support pad&align (see Release Notes)
lwhuang + 2 感謝分享
GMT+8, 26-11-5 05:04
