查看: 5687|回復: 0
AmiQuote 3.14 released
發表於 17-5-18 09:14 | 顯示全部樓層 |閱讀模式
May 17, 2017AmiQuote 3.14 releasedA new preliminary version of AmiQuote 3.14 is available for download from
http://www.amibroker.com/members/bin/early_aq3140.exe  (100KB) – 32 bit version
ATTENTION:
This is MEMBERS ONLY download. You need to have active AmiQuote license and active AmiBroker support & maintenance package to download and use it.
This version fixes problem with Yahoo Historical and Yahoo Fundamental Extra sources that stopped working after changes on Yahoo site.
The upgrade is free for all previously registered AmiQuote users.
IMPORTANT NOTE for AmiBroker 64-bit users:
Because of the transition to new compiler, 64-bit version 3.14 is postponed, you can use 32-bit version instead (just place QUote.exe into correct directory C:\Program Files\AmiBroker\AmiQuote and aqh.format file into C:\Program Files\AmiBroker\Formats)
If you are getting volume and price mixed up it means that you did not copy new aqh.format file that is inside “Formats” subdirectory.
GMT+8, 26-11-4 23:27
