樓主: Dogfaceman
Amibroker透過ABTW接收群益即時報價步驟
 火.. [複製鏈接]
發表於 11-3-4 09:15 | 顯示全部樓層
kilroy 前輩
Please save me out of the question.
發表於 11-3-4 09:36 | 顯示全部樓層
Question:
And How to save the real time data after the end of day?????
and conbine the data for each ...
george.ct 發表於 11-3-4 08:55 AM
如果要讓realtime data 在收盤之後都存下來,以及歷史資料都在的話
必須使用 DDE 餵資料給 amiBroker 的方式才可以喔
用 ABTW 的話就是每天都要重複同樣的動作
1. 收盤後下載期交所資料與歷史資料合併
2. 開盤前匯入歷史資料
希望以上回答有幫助
發表於 11-3-4 10:29 | 顯示全部樓層
可是my realtime data seems can not save.
Just like today I open the same database but yesterday the realtime data see nothing.
I am using the AB 5.30  RCversion, is it anything wrong.
發表於 11-3-4 11:46 | 顯示全部樓層
試用版資料是無法儲存的, 您不會是在用測試版吧
發表於 11-3-4 12:41 | 顯示全部樓層
只要是用ABTW的話 一打開AB 就會清光所有歷史資料
所以我都另外開一個新的資料庫當作盤中交易用的資料庫
發表於 11-3-4 13:17 | 顯示全部樓層
Oh, Actually I'm not play 測試版
Maybe the one I get which is not 解 clearily. Just workable better than 測試版
Sorry to ask you that do you know which AB version of this function is working perfectily.
I gona google for this version and than test it.
發表於 11-3-4 13:37 | 顯示全部樓層
沒有註冊就是測試版...
您可到官網看看說明....
發表於 11-3-4 13:41 | 顯示全部樓層
Another question of  the ABTW collect the data via 群益贏家策略王 API, But the price quote and volume of AB data seems a little bit differ from  群益贏家策略王 price quote and volume. Is it time lag of "AB's problem" or "群益贏家策略王 API problem" or " ABTW " problem, sorry to say that to the "ABTW" 's creator, Maybe the "ABTW" 's creator forget some parameter of API or something, If possible I wish that I have chance to 請益 "ABTW" 's creator, why the difference between the "AB" and  the "群益贏家策略王看盤price quote and volume"
Thanks a lot
And thank you 木川 Sir.
發表於 11-3-4 13:47 | 顯示全部樓層
Thank you moneymaker
You let me 破功 but let me got the answer.
Thanks again
But I think u  know  for certain which version workable for realtime saving.
發表於 11-3-4 13:57 | 顯示全部樓層
Hi moneymaker:
You can tell me sececily. I promise won't tell anyone.
發表於 11-3-4 14:02 | 顯示全部樓層
I still not 幻滅
I still evalue the AB but need longer time to test it.
發表於 11-3-4 14:08 | 顯示全部樓層
難道真逃不過這樣的命運
How about v5.0 v5.2 or..........v4.8...
中毒已深
發表於 11-3-4 14:15 | 顯示全部樓層
綠茶妹救救我吧
你一定知道這個Key
發表於 11-3-4 15:21 | 顯示全部樓層
本帖最後由 george.ct 於 11-3-4 04:55 PM 編輯
請問有誰會DDEChartUpdater設定?
發表於 11-3-4 21:57 | 顯示全部樓層
本帖最後由 wldtw2008 於 11-3-4 10:00 PM 編輯
GEORGE.CT大您的AB怎麼這麼多問題?
1.
QUOTE我是故意累積0.4秒才送,但是TICK是即時反應的。
2.
盤中K線,AB好像是三秒更新一次,但是事實上是每個TICK都有算,只是[更新]有點慢,這個數值是可以調整的
3.
不過,也很有可能AB新版有改東西,跟我以前寫ABTW的時候不同,所以我們之間有點雞同鴨講
GMT+8, 26-11-5 06:39
