查看: 10555|回復: 31
AmiBroker 5.60.3 official release
發表於 12-12-6 17:59 | 顯示全部樓層 |閱讀模式
December 5, 2012
Stability: Rank 5 – Release version, stable
A new official version (5.60.3) of AmiBroker has just been released.
32-bit version:
http://www.amibroker.com/bin/AmiBroker5603.exe
(8 608 360 bytes)
64-bit version:
http://www.amibroker.com/bin/AmiBroker5603x64.exe
(9 081 416 bytes)
These are universal setup files. They can be installed on fresh windows without need to install any previous versions. They can also be used to upgrade existing installations.
ATTENTION: This version is free only for users who registered after April 12, 2011. See Upgrade Policy and Pricing section below for more details.
IMPORTANT: This version is available to general public, not only members
CHANGES FOR VERSION 5.60.3 (as compared to 5.60.2)
    Corrections and updates to Users’ Guide
    3D optimization chart was corrupted when optimization included custom metrics. Fixed.
    Custom backtest procedure was not called when number of trades was equal zero (no trades at all). This prevented creation of custom metrics in such case. Now CBT code is called anyway.
    New Analysis, database’s time shift was applied twice in “Show current trade arrows” mode. Fixed.
    New Analysis, when Apply to was set to “Current” then changing current symbol during optimization affected results. Fixed
    When custom backtest formula was defined in separate file then report “Formula” tab shown CBT formula instead of actual system formula. Fixed.
參與人數 4金錢 +10 收起 理由
upupdowndown + 2 感謝熱心回覆
manhavecoco + 1 按一個讚!
kilroy + 5 按一個讚!
enochyu + 2 按一個讚!
發表於 12-12-18 12:12 | 顯示全部樓層
本帖最後由 zaqimon 於 12-12-18 12:19 編輯
不小心google了一下amibroker 5.60.3
沒想到...  竟然會這麼簡單
發表於 12-12-18 12:48 | 顯示全部樓層
zaqimon 發表於 12-12-18 12:12
沒想到...  竟然會這麼簡單
真的嗎
發表於 12-12-18 15:05 | 顯示全部樓層
新版看起來就很不一樣
背景還可以自定漸層
 樓主| 發表於 12-12-18 17:27 | 顯示全部樓層
對了,有必要提醒一下,32 / 64 位元有點不同
要用64位元者,先看一下:
http://www.amibroker.com/guide/compat.html
64 位元的data sources沒有DDE這項
發表於 12-12-19 02:47 | 顯示全部樓層
@Sirius, DDE is a product by Microsoft. Tomasz Janeczko the developer of Amibroker can't do anything about it. DDE does not work on 64-bit. Blame Microsoft. ;)
發表於 12-12-19 10:10 | 顯示全部樓層
joey0415 發表於 12-12-19 09:52
我也google一下,真的很漂亮
感謝提供訊息
俺google  一下 怎沒看到 漂亮的
 樓主| 發表於 12-12-19 17:06 | 顯示全部樓層
本帖最後由 Sirius 於 12-12-19 17:08 編輯
joshsmi 發表於 12-12-19 02:47
@Sirius, DDE is a product by Microsoft. Tomasz Janeczko the developer of Amibroker can't do anything ...
這一點我知道的,所以才會特地提出來
有些開發工具都於DDE的支援已不太注重,甚至也不更新了
M$在64 bit不再繼續使用DDE是正常的,畢竟早就有別種方式可代替,只是部分應用軟體一直停留在舊方式
發表於 12-12-19 18:12 | 顯示全部樓層
本帖最後由 zaqimon 於 12-12-19 18:34 編輯
反正現在的程式八成都還是32bit的
在Win7 64bit安裝32bit的AmiBroker就可以繼續用DDE了
沒事不要自找麻煩安裝64bit程式
補充一下在國外網站上看到關於IPC的文章
有一段對DDE的描述翻成中文如下:
微軟不想要我們繼續使用DDE的原因可能是
a. 它不夠耗CPU資源來讓使Intel高興(it doesn't consume enough processor cycles to keep Intel happy)
b. 它可以運作(it works)
發表於 12-12-27 20:39 | 顯示全部樓層
偷懶請問各位一下,
這個AB 5.60.3的版本,有試用版嗎?還是只有正式版
1.
有試用版的話,是使用天數限制?還是有功能上的限制?
2.
AB 正式版,大概要多少錢?
 樓主| 發表於 12-12-27 20:51 | 顯示全部樓層
upupdowndown 發表於 12-12-27 20:39
偷懶請問各位一下,
1.
看一下置頂的文章
AmiBroker購買或試用
發表於 12-12-27 21:18 | 顯示全部樓層
但是 MultiCharts x64 版本, Data source 有 Universal DDE 可以用. 為什麼 AB x64 就沒有辨法使用 DDE ?
發表於 12-12-28 01:13 | 顯示全部樓層
Sirius 發表於 12-12-27 20:51
看一下置頂的文章
AmiBroker購買或試用
感謝樓主的貼心連結....
(所以才說偷懶一下囉)
也奉上Co幣聊表心意
 樓主| 發表於 12-12-28 15:51 | 顯示全部樓層
sdnian 發表於 12-12-27 21:18
但是 MultiCharts x64 版本, Data source 有 Universal DDE 可以用. 為什麼 AB x64 就沒有辨法使用 DDE ? ...
我也好奇很想瞭解為什麼
不知是還沒做好,還是不想做?
發表於 12-12-28 17:03 | 顯示全部樓層
Sirius 發表於 12-12-28 15:51
我也好奇很想瞭解為什麼
不知是還沒做好,還是不想做?
我個人想法是這樣... AB 會有什麼功能, 完全由作者一個人主觀的意思來決定, 當作者不認為某項功能是有需要的, 他自然就不會花時間在上面. 舉個例子, AB 提供的 for IB 的 plugins, 我個人覺得很爛, 最多只能匯入 180 天的資料.. 而且如果真的選 180 天, 常常會不太順, 有時沒全部做完, 再不然就是一直出現在等待.. 如果你去問作者, 他會說那是 IB 的限制, 就如同 DDE 一樣, 他會說是 Microsoft 的問題..
可是我們用 MultiCharts 來看同樣的功能, MultiCharts 可以匯入 IB 一年的資料(一年這是 IB 的限制), 而不是 180 天.. 而且如果同時從 IB 太多資料, MultiCharts 確實也需要等 (這也是 IB 的限制沒錯), 但是基本上是可以確實完成的, 不會像 AB 有時候根本沒做完, 要一直反覆做好幾次回補的動作.
是 AB 的作者技術不夠嗎? ... 絕對不是, 我覺得他的技術很強.. 根本是他想不想做的問題.
當然 AB 和 MC 的價格不在同一個層次, 所以拿二個來比較, 也不太公平就是了. 而且 AB 和 MC 二者的定位似乎也不太相同, 我個人感覺 AB 比較是研究用的.
GMT+8, 26-11-5 06:40
